Brake Pads choice
#41
there are clips on top of the pads each caliper. One clip covers both pads. You have to push them down and slide the pins over the top of the clips. When you push those pins through the clip the clip springs upward and puts pressure on the pin. Then you have to tamp the pin through — I did this with a small ball peen hammer then I used a small drill bit I broke in half placed on the back side of the pin to tamp it all the way through until it stops. Those clips need to be in there. The powerstops I bought had new clips in the box. I did use the new clips and saved my old pads with the old clips in the power stop box.
Check out youtube. Do search on c7z06 pad replacement. You’ll see what I am talking about
As as far as clips. You may also be referring to the wear sensor. They look like a little hook. Those were on the inside pad of each pad facing downward as I recall. Just in case that’s what you are referring to. If you want take a picture of the clip and post it. And that can help me guide you.
#42
no it won’t make a difference. By placing them downward, when the car is up on a lift you can check the distance of the sensor to the rotor. With them up on top you can’t really see them. You would only be able to hear them when the pad wears down and the sensor touches the rotor.
#44
Those pads will last a long time a lot longer then the factory pads.
Where is your location? I am in the Midwest St. Louis Missouri.
#45
Wayyyyy North of you , Timmins Ontario Canada . Home town of Shania Twain
#46
Maybe I missed it somewhere in this thread, but do these recommendations include for a C7/Z06/Z07 with the Carbon Ceramic brake rotors? Looking for a pad recommendation for the CCB rotors. I have 10k miles on the car and got the "brakes worn" message in the car, which I wasn't expecting so soon, as I haven't even gotten to track the car yet.
#47
Supporting Vendor
Ken
#48
Problems with powerstops
I swapped mine out. Great low dust. 2016 z-06. I don’t track but drive hard. I burnished the pads like powerstop tells you. I have them on my truck and another car and no issues.
I just did 150 the other day and braked pretty hard and now I have some strange marks on my front disc. Drivers side.
And the car shuddered as I put the brakes on. Not smooth at all.
My rear pads have both seemed to chip on the corner and making a groove in my rotors.
So I don’t know what’s up but I’m thinking it’s the pad
#50
Too much grease.
If
Took everything apart. All four wheels. I think I put way to much grease on the back of the pads. Bremnen doesn’t recommend grease there. Only on the very ends where the pads ride on the caliper.
A lot of small gravel stuck to the back of pads.
#51
Wow , I'm glad i was pretty cheap when i put the grease on them , haven't driven the car yet though as its still snowing here and temps are still below Zero
#52
Supporting Vendor
St. Jude Donor '11,'13
That's not grease... You over heated the pads.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#53
#57
So far as I can tell it was all the grease I put on back.
The rotors appear to working good I’m getting good contactpad to rotor. Not brown looking now.
Like I said brembo recommends no grease on the back of pads.
#58
Well just to report back after the install and first ride this year . Took the car out this past Thursday as the weather , finally went to 14 degrees here . Drove to a coffee shop ( Tim Hortons ) applying the brakes numerous times both there and back . Never heard any squeals , nice smooth stops , best of all No brake dust Think ill get a set for the Shelby next
#59
