Z06 warranty denied bc track
Tells you in the book that came with the car. Page 165.
https://my.chevrolet.com/content/dam...s%20Manual.pdf
Participating in track events or other
competitive driving without following
the instructions provided may affect
the vehicle warranty. See the
warranty manual before using the
vehicle for racing or other
competitive driving.
“If you’re not modifying your car and you take your production car to a track day and you have an issue with one of your parts, it’s covered under warranty,” [Camaro chief engineer Al] Oppenheiser told Motor Authority. “That’s pride of craftsmanship that we know it will stand up to track use.”
Which is the same thing I pointed out in Post #2.
Redc8z06 (03-19-2018)
Received 8,915 Likes
Sounds like this is a good problem to send a letter to Mary Barra about. First, the dealer's tracking response is suspicious and the fact they will not let you talk to the GM rep is suspicious. When you have a dealership like that you need to start at the top and Mary sits right at the top. Every time I have sent letters to the President or CEO of GM I have received excellent results. Just politely tell them the problem, what will make you happy (don't make it a guessing game) and you should receive some sort of acknowledgement from somebody assigned to review the case within a short time after the letter has been received. Include copies of all repair invoices and amounts you have paid. The first time I did this the dealer was found to be charging me for the repair and then turning around and charging GM for the repair under warranty. That complaint had a few people at GM upset.
Bill
Bill
Received 3,787 Likes
"Ask Tadge" Producer
...and go after the guy that sold the OP the car. Not GM.
Good luck with that one. It was likely sold in an "As Is" state, meaning there's probably nothing our OP can do but take it on the chin and pay for it himself.
just got back from inspecting the diff at the dealer. It clearly hasnt overheated or burned up. Just improper wear and tear on the rack and pinion probably from improper factory set up. most likely the same noise i read about in lengthy posts here on the forum where the only fix is a new diff. This has zero to do with the track and the corvette tech almost admitted it. The service manager said hes tired of seeing gm deny so many claims so hes not willing to risk it..Great warranty...def. not going to drop 130 k on a zr1 with a company that wont cover the warranty when somethings not right. The manager is going to try to get the local rep to reconsider but im not holding my breath. It just makes me mad that they basically made up there minds that they wouldnt cover it befoe even breaking down the diff.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Did I miss where it stated whether the rear was, or was not, properly broke in, or is JVP just being a douche for no reason?
GSpeed (03-21-2018)
I'll still bet the fluid level was low from the factory.
mcoomer (03-23-2018)
Unfortunately, this is due to improper break-in. Whether at the track or not, this is precisely why you take it easy on the car for its first 500 or so miles. Failure to do this will probably result in: a howling differential. Just like what you're experiencing.
This is a fault of the previous owner. But it's not something GM should be expected to cover under warranty at all. Not in the least. It's documented plainly in the owners manual that you're supposed to take it easy on the car for the first 500 miles, and don't touch a race track for the first 1500 miles!
My 2015 Z06 was broken in perfectly per the manual and my diff still went at about 750 miles. And of course GM covered it.
It's not that I reject your theory that improper breakin can cause a failure, because that part is true. The part where you attribute every diff failure to owner negligence? That's must nonsense.
Unless I missed it, there's no indication that the track use was during the breakin period.
How do you know whether or not he ever talks to the GM rep? If this isn't covered you need to insist on talking to the GM rep when he comes by. That may mean leaving work to go see him when he/she is at the dealership.
Talk to somebody in GM and the best person is at the top. You will get a response.
Bill
#33
Received 2,379 Likes
The service manager said hes tired of seeing gm deny so many claims so hes not willing to risk it.The manager is going to try to get the local rep to reconsider but im not holding my breath. It just makes me mad that they basically made up there minds that they wouldnt cover it befoe even breaking down the diff.
GSpeed (03-21-2018)
#34
Again, it's his JOB to submit repairs for warranty for YOUR car. YOU are the vehicle owner, the warranty is a contract between you (as a successor to the original owner). Manufacturer's warrant the vehicle and the warranty transfers with the car. Aftermarket or third part warranties are often a different story, but not the GM warranty.
Tell him to shut up and do his job. Or, find another SM who actually understands what his role is in the process.
#35
Well personally if that's the case then the power is pointless. i guess we are just paying extra for bragging rights.
#36
GM published a list of cars which are covered on track, Z06 included. I don’t have it handy, but I’m sure you can find it if you google it.
It’s one of the key things that separated the Z06 from the GT3. The porsche owners manual specifically states track use voids the warranty.
I’m planning to buy a ZR1, but ONLY if track use is covered.
If the OP isn’t taken care of, I’ll have to reconsider the ZR1.
#37
The C7 e-difs are known to be under filled with fluid from the contractor Linimar. Checking the dif fluid level is not part of the PDI, even at Museum delivery. One CA customer took Museum delivery and oly made it to TX before the under filled dif failed.
Talk to you service adviser about this, likely no satisfaction, the go thru GM channels.
#38
#40
Hope you get this resolved. I noticed that a couple of times you referred to the rearend problem as a rack and pinion issue. That is the steering rack in the front of the car. You probably mean to say ring and pinion which is the gearset in the rearend.
