2019 brake pad dust?
Old 04-07-2018, 10:31 PM
Westy39
Junior Member
Liked 0 Times in 0 Posts
Default 2019 brake pad dust?
When I bought my 2013 GS I changed my brake pads due to the dusting issue. I have a 2019 Z06 on order, is the brake dust an issue on the new Z06 models?
Westy39 is offline
Old 04-07-2018, 10:46 PM
MM23
Junior Member
Yes, Unless you have ceramic pads you will have break dust regardless of what year car you have.
MM23 is offline
Old 04-08-2018, 07:55 AM
gve
CF Senior Member
gve's Avatar
Liked 331 Times in 147 Posts
Get the Powerstops about $130, less dust without paying the corvette tax.
gve is offline
The following users liked this post: gve
frankmp (03-27-2019)
Old 04-08-2018, 08:59 AM
b4i4getit
CF Senior Member
b4i4getit's Avatar
Liked 244 Times in 169 Posts
Get some new pads and maybe your tech will change them out for free.
b4i4getit is offline
Old 04-08-2018, 02:34 PM
Bill Dearborn
Bill Dearborn's Avatar
Liked 3,482 Times in 2,325 Posts
They dust but it isn't an issue. It is the nature of the beast. There is nothing wrong with brake pads that dust.
Bill
Bill Dearborn is offline
The following users liked this post: Bill Dearborn
badhabit_wb (03-28-2019)
Old 04-08-2018, 03:23 PM
Mr. Gizmo
CF Senior Member
Mr. Gizmo's Avatar
Liked 320 Times in 256 Posts
Originally Posted by [email protected]'dAutosport.com View Post
If your just driving the car on the street your going to want to change your pads. I recommend the Carbotech 1521.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
the Carbotech 1521 soliloquy
Mr. Gizmo is offline
The following users liked this post: Mr. Gizmo
Old 04-08-2018, 03:35 PM
Jim Barker
CF Senior Member
Jim Barker's Avatar
Liked 31 Times in 21 Posts
Also the pads drop in without removing the calipers on these models.
Jim Barker is offline
Old 04-08-2018, 03:38 PM
16/C7Z
CF Senior Member
16/C7Z's Avatar
Liked 1,201 Times in 932 Posts
if you have ocd. like others have said, change the pads. because even a short drive will show a ton of dust. i did the powerstops. perfect solution, i used to clean wheels off after each drive because i didn't want the dust to eat into the clear on the wheels. i haven't cleaned my wheels in about a thousand miles. says a lot.
i have about 10 or so videos of my swap. they're short clips of my trial and error. if you want to see how easy it now it.
16/C7Z is offline
The following users liked this post: 16/C7Z
Old 04-09-2018, 04:04 PM
hebegb
CF Senior Member
hebegb's Avatar
Liked 37 Times in 27 Posts
Powerstop Z26 is the way to go for low to no dust. Part numbers are 1405 for the front and 1718 for the rear.
hebegb is offline
Old 04-09-2018, 07:10 PM
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
Liked 217 Times in 200 Posts
St. Jude Donor '11,'13
If you want a quality aftermarket pad I recommend the Carbotech 1521 pad. A low dust pad that is rotor friendly and performs like OEM and last longer. 100% non-corrosive dust will not harm your paint or wheels. This pad also contains NRS technology. Carbotech uses NRS technology on all C4, C5, C6 & C7 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
If interested I will be happy to help you out or you can order online here http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out for your 5% discount.
ZO6/GS part numbers.
F: CT1405
R: CT1718
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: [email protected]
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam@Amp'dAutosport.com is offline
Old 04-09-2018, 08:11 PM
3 Z06ZR1
CF Senior Member
Liked 848 Times in 703 Posts
Bill
Oh my yes it is to some Bill if you care about keeping your car clean. I guess I'm one of the only ones that actually even cleans under the doors.
The brake dust goes all over the car. Esp lower under the car and under the doors coating the rims and calipers. Bad stuff!
3 Z06ZR1 is offline
The following users liked this post: 3 Z06ZR1
tzoid9 (02-20-2019)
Old 04-10-2018, 01:26 PM
Bill Dearborn
I used to do actual car shows where judging was done with a flashlight. I know about cleaning every nook and cranny including the doors and in the space around the door hinges. If the eye can see it it gets cleaned or if a judge asks you to use your fingers to wipe the bottom of the door your finger better be clean when you remove it from the door.
I get a lot of brake dust out of there every time I wash the car but I like stopping better than I hate cleaning brake dust. When pushed hard the low dust ceramic pads don't cut it on hard stops especially if you do it multiple times in a few minutes. Right now I have a set of Ferodo 1.11 pads on the car and they dust the wheels and side of the car before I get more than a quarter mile from the house.
Bill
Old 02-19-2019, 10:13 PM
2019 ZO6
Junior Member
I wanted to purchase a set of Power Stop Z26 ceramic brake pads for my 2019 ZO6 with steel rotors. When I type in my 2019 ZO6, they say the brake pads don't fit my vehicle. I even tried typing in 1405 and 1718 and it still says it doesn't fit my vehicle. I called the customer service telephone number on Powerstop.com website and they told me it will not fit and they don't have any brake pads to fit my vehicle. What is going on?
2019 ZO6 is offline
Old 02-19-2019, 10:19 PM
ZO6 cracker
CF Senior Member
ZO6 cracker's Avatar
Liked 125 Times in 110 Posts
I bought mine from Adam’s on the post above and had dealership put them on my 19 Z06 before I drove it home.
ZO6 cracker is offline
Old 02-20-2019, 08:02 AM
Big Lebowski
CF Senior Member
Big Lebowski's Avatar
Liked 447 Times in 250 Posts
yes, nature of the beast.
Big Lebowski is offline
Old 02-20-2019, 09:19 AM
Supporting Vendor
If you would like a set of Carbotech 1521 pads I will be happy to help you. I have them for 19's.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 02-20-2019, 09:54 AM
ronsc1985
CF Senior Member
Liked 71 Times in 58 Posts
Probably their data set has not been updated to 2019 models. Look on Rock Auto.com. They have Powerstop listings for 2019 models with iron rotors.
ronsc1985 is offline
Old 02-20-2019, 06:58 PM
tertiumquid
CF Senior Member
tertiumquid's Avatar
Liked 148 Times in 93 Posts
Bill
True, but it isn't fun cleaning the wheels every 50 miles or so.
tertiumquid is offline
The following users liked this post: tertiumquid
tzoid9 (02-20-2019)
Old 02-20-2019, 10:23 PM
bertha
Junior Member
Liked 1 Time in 1 Post
Tagged, this seems like a very interesting thread
bertha is offline
Old 03-27-2019, 07:08 PM
Mike Vanbenthuysen
Junior Member
Default 2019 Z06 pads
My boss has a 19 Z06 and is looking for a low to no dust pad. Let me know how these can be purchased, and if in fact they are low to no dust pads. Thanks
Mike Vanbenthuysen is offline
Quick Reply: 2019 brake pad dust?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
