DSC Rear aftermarket toe links?
Anyone know +1.5mm total or each side? With aftermarket toe links. Also I did the V3 update and when I zero the ride height it showed 0 but it didn't say ride height anyone else notice this? Thanks
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
If you zero ride height and it says 0, you did not do it correctly. I believe the key must be on for the shocks to read, it should have values in the 1500-2000 range IIRC.
With the rear toe links I believe you also go to zero toe or slightly in, not toe out as with the OEM set up.
tracer3030 (04-21-2018)
It's 1.5mm toe in each side in the rear with the granatelli rear tire links.
