Active handling 345 drag radial
2019 zr1. Doing 18” wheels all around. 345 mickey drag radials on rear
to not have active handling issues - what size front tires are you c7 guys running?
i have heard 3% difference or 1/2” difference is ok?
This may be my issue on my Z06.
M/T SR fronts, 6 X26.
Hoosier 315/30R18 rears. They are actually 25.5 in. tall.
Try and heat the tires up and it sits there and spits/blubbers away.
It will also drop power on the 1 to 2nd gear change.
1 good run out of 7, 6 are throw always.
I did notice an Active Handling message near the speedo at the end of a run.
It never acted this way with the stock tire set up.
I'm stumped.
I'm stumped.
Received 8,918 Likes
I'm stumped.
I'm stumped.
Bill
Thanks so much for the reply Bill.
Unfortunately no one makes a shorter 18 in. front skinnie that I'm aware of.
There are a few options for the rears though.
Thanks again.
Thanks again.
