We might be getting a "high wing" Z06 or GS...
If it is a more dedicated track version, there are those that are already good enough to push their current Z06s to the point of overheating. I would think that this one with the wing could be pushed harder through the twisties. Maybe this has the fix for the overheating issue that the track guys need?
Ford has 7 liter DOHC engine slated for 2019 Raptor, top shelf F-150, other large trucks with the occasional rumor for special Mustang yet to be mentioned. Rumors of Dodge 426 Hemi have surfaced occasionally as well, most likely for trucks as well but it has been mentioned for special edition Challenger. Talk of any large cube DOHC powerplant from GM has strangely been non existent as far as I know. Could the trademarked L88 still be a possibility?
Since there is no bulging ZR1-type hood on it, I suspect this is an NA.
Possibly the LT1 or some unknown engine.
Also, after examining it closely, IMO this looks like a fully-formed model...notice the Corvette flag logos front and rear are missing (weight savings?).
We should expect an announcement very soon.
Maybe I missed something obvious but why is this car assumed to be ZO6 related rather than GS related? If built primarily for track use a supercharged engine would likely be outfitted with front end similar to ZR1 style front fascia to accommodate enhanced cooling. Bodywork in photos seems more likely of GS variant with NA motor. GM succeeded stirring the imagination cruising with windows down and orange roll bar in plain view along with orange high wing and red tow hooks.
Oddball car. It has parts from 3 different modes. Wonder what's going on in the Chevy garage.
Side note: The wing and its decreased drag should reduce engine workload(and heat) versus the lip spoiler while increasing high speed acceleration and downforce. The LT4 works extremely hard vs drag on the Stage III cars as many of you well know.
If I were a Stage II owner that did some occasional racing whether drag or road racing or I might consider finding a way to put on the ZR1 low wing.
In all honesty - there were maybe 4 cars in total that had a huge wing on the back - none were corvettes and most of the big wings I saw were on cars in the 170 or class - go figure!
Premium Supporting Vendor
Could we see an N/A Z06X....again...GM has my hopes very high...but i'm sure I'll be disappointed. Many insiders swore and claimed information existed that the Z28 Camaro would debut with an N/A engine, and recent spy photos have located a ZL1, without aero and carbon brakes on it...meaning there COULD be a Z28 with an NA engine on the horizon and no one to share it with....unless big wing Z06x needs it!
Received 1,817 Likes
Large displacement engines don't benefit as much from high rpm's as smaller displacement engines. There are showroom-stock smaller motorcycle engines which rev 12 to 16,000 rpm, with a factory warranty.
With larger displacement engines (including a longer stroke), piston speed may be the limiting factor, for reasonable longevity. Oil films can do some funny things, when surface speeds go beyond a certain point.
One of the early discoveries was that the colder cylinders in an engine had increased wear, compared to cylinders in the same engine, under the same operating conditions, which operated at higher temperatures due to variances in coolant flow.
#34
I was at this years Silver State Classic in Fort Stockton this year. Plenty FAST blind downhill corners (90 mile course) and didn’t see any of the stupid looking wings on a Vette - not even in the 212 MPH class!
#35
It does have cues from the C7.R.
Much more work than would be done on a mule.
OTOH, it doesn't surprise me if a lot of owners don't know a thing about professional racing.
#36
Received 3,987 Likes
Why is no one talking about the way cool FLAT paint finish?
sunsalem (05-22-2018)
#37
#39
#40
Supporting Vendor
Received 2,316 Likes
We could see something come outa left field here because the side vents without badge, the wheels, etc are all Z06
Is C7 going to pull off a version JUST FOR ME, late in the 7th-8th inning here!?!?!?
CPhelps (05-23-2018)
