Metco LT4 2.3" blower pulley in stock and ready to ship at Juiced Motorsports
#44
Former Vendor
Install charges are usually around $200 and the temps increases are minimal. If your system is properly filled you won't have any affect.
#45
What does this do to the thermal load including IAT?
I have a 2019 M7 Z-O6. I am concerned about the increase RPM of the super charger increasing the thermal load. I would like to solve the cooling issue prior to increasing the thermal load. Do you offer any solutions to the increased Thermal load? The real issue is the RPM of the supercharger creates more heat than the cooling can handle. The ZR-1 goes with a bigger supercharger so it does not have to turn as fast. Cooling is far less an issue. What advances in cooling does Metco offer. Thanks
#46
#47
Former Vendor
That's a great way to go with these cars having cooling issues to begin with. Most issues have been linked to air in the line. Since these cars don't have a reservoir they need to be pressure filled and not everyone knows how to do that properly. IMO the most important mod is to have a reservoir on these cars so you can fill it properly (and also add volume to the system) and then add a heat exchanger upgrade.
