GM OEM or ACDelco "Original Equipment" Brake Pads
I believe the following parts are correct for Z06 steel rotor brake pads
Front GM OEM 25940447, ACDelco "Original Equipment" 171-1040
Rear GM OEM 22847818, ACDelco "Original Equipment" 171-1127
I have seem some references to this which I can no longer find. Is it known that they are truly the same brake pads?
Thank you for your input.
Scott
Scott
I would encourage you to look at the different pads available for our cars. There are many that are far superior to the a/c delco offerings. I run Powerstop rotors and track day pads for autoX and road course and the Z26 just for street use, and they have almost no dust and are very affordable.
Scott
Scott
