Competition Carbon front bumper and ZR1 cooling compatible!!
we are talking about the back of the car now Badhabit, thats probably where you lost us.
Mikec7z (09-12-2018)
The rear alone can solve 90% of peoples overheating issues, and leave their noses stock.
The rear should be a much less expensive part to supply. Very easy to add a couple rectangle cut outs and put a vent/screen over each, for the coolers to sit behind
These cars are too wide as it is
wildgoat (07-25-2018)
As for my hope. I want to do the Gspeed cooling mod. I think the nose must be addressed.i do not care for gspeeds nose or LGs nose so this is exciting, but also agree if some of the cooling can be addressed at the rear of the car would be good as well.
Former Vendor
So many projects to get done for SEMA. Two workers quit too, plus this heat!! Will get it all done though.
You can see where I get the inspirations from. Performante bumper is so beautiful!!
Mikec7z (07-20-2018)
Sema
checking in
Sub'd. The front bumper looks sick! Yes, this will be a hot seller assuming the price is competitive. I am not one for Carbon. I will take the same design in a material similar to OEM.
I hope you can provide a step-by-step instruction of how to install the ZR1 cooling and plumbing and have it married to this bumper. Hopefully we can use the existing Z06 nuts and bolts to make this happen.
P.s. I hope you have an assembly line ready because this bumper will be a hit! Hopefully you can also offer a painted option from the shop directly to the consumer.
#33
Former Vendor
Swamped with filling orders. This is what I got as of last Wednesday. Will see if I have any more progress pics today. As far as cooling kit, you can use ZR1 coolers with a full LT5 blower swap or just making your own lines and pumps. Shouldn’t be too difficult since coolers can be adapted for personal kit easily.
Mikec7z (08-13-2018)
#36
Will this come with a separate splitter? Geiger has an intgrated splitter that looks like it would put the whole nose at risk of damage. Would also really like to be able to mount front cameras. I am thinking gspeed cooling mod and your nose on my Callaway and then that will be what a Callaway should be and look like.
#38
Former Vendor
Just need to get more filler to add these highlighted divider to the opening and I can figure out where to mount the front cameras (middle opening or outer openings side)
#39
It would be best to mount it in the middle opening. That is what Katech / TIKT cooling does as well. The ZR1 also has in the center grill.
I know all the engineering you've been doing is based on the ZR1 cooling. I know LG motorsports is looking at offering their front coolers to be paired with yours as well. What will work with this grill is the wide range of possibilities with different vendors and their cooling parts.
P.s. Would be great if you can someone photoshop this grill in different color for the Z06.
Deity.Motorsports (08-14-2018)
#40
Former Vendor
Mikec7z (08-14-2018)
