Anybody put a ZR1 thorttle body on their Z06 yet
#61
8850, no the one I took off was stock. I have done no other mods other than what I mentioned and it’s the canned diablosport 93 octane tune. I agree that porting the snout would be beneficial but I have not done that yet. As far as rust that minor surface rust you pointed out is of zero consequence and I’m not worried about that at all.
#62
#63
pipe was only $400. That little bit of surface rust won’t cause an issue. You can always have it jet coated.
#64
St. Jude Donor '14
We have the LT5 TBs with the spacers for sale here
https://weaponxmotorsports.com/produ...=8667505262683
#68
#69
swaite, do you have any 1/4 mile results compared to the stock TB yet?
#70
I’m not a 1/4 mike runner. I did it as an experiment to see how it runs. Given my current mods it seems to work well. I can only imagine better results with a lt4 snout ported to match the lt5. I think your money is best spent on that vs a ported lt5 TB as the snout on the lt4 is smaller than 95mm
#71
I ordered the stock ZR1 95mm TB (GM part #12669871) & (ICT part #551793) billet adapter plate.
No porting will be done to the TB, running it as delivered with the stock tune and a AFE CAI (dry 'low flow' filter installed) at the strip with hopefully positive results.
#73
#76
There are two different adapters available from ICT. One that clocks the throttle weirdly like that, and then a standard clocking adapter. Try this link instead...
https://www.ictbillet.com/gen-5-lt5-...or-lt4-sc.html
#77
You are right, I saw that being mentioned before.
The background of my question is, that GM offers other 95mm TB that will fit, but the electric connector is in a different Position, requireing the cable to reach app. 3-4" further - like in the Picture above.
#79
I wanted to install the TB with the adapter and realized that it adapts the mounting holes, but not the diameter. It is 95mm in and out.
Regards
Götz
#80
Correct. No point in putting on a bigger throttle if it just gets choked down at the snout entry. The snout really needs opened up to match as well for it to be beneficial
