No remote detected
Old Sep 17, 2018 | 01:59 PM
2019 ZR1's Avatar
2019 ZR1
Default No remote detected
At first I thought it was because I only use the one remote and the battery must be going bad. I tried the other remote yesterday and it did the same thing. I finally got it to start but very frustrating. I tried putting the remote in the slot under the steering wheel but it didn't seem to affect it. Anyone have this problem??
Old Sep 17, 2018 | 02:06 PM
badhabit_wb's Avatar
badhabit_wb
I had the same problem with mine and put batteries in both remotes and that fixed it. cr 2032
Old Sep 17, 2018 | 04:05 PM
SoCalFinest's Avatar
SoCalFinest
hit the unlock button on your remote so it'll recognize it. Such a hassle tho :/
Old Sep 17, 2018 | 04:29 PM
2019 ZR1's Avatar
2019 ZR1
I tried that and it didn't do anything. After a few times getting in and out it will start. I just ordered new batteries and I hope it takes care of the problem.. Thanks man!!
Old Sep 17, 2018 | 04:30 PM
2019 ZR1's Avatar
2019 ZR1
I just ordered new batteries.. Hope it takes care of the problem.. I appreciate the info... Thanks man!! I was trying to figure out what the hell the cr 2032 meant then I looked the batteries up and I realized that is the batter number.. Lol
Old Sep 17, 2018 | 06:42 PM
383vett's Avatar
383vett
If the car battery is low on charge, it can have trouble recognizing the remotes. Went through this a couple of months ago.
Old Sep 17, 2018 | 07:42 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Agree with above. Bad car battery can produce the same problem. If the new batteries you ordered don't fix the problem (by the way, Home Depot carries them) then get your car battery load tested.
Old Sep 17, 2018 | 07:48 PM
badhabit_wb
If you replace it put in an AGM battery like an odyssey. It will have more power and it will last longer
Old Sep 17, 2018 | 09:33 PM
Dale06's Avatar
Dale06
Exact same thing just happened to me. No remote detected. I put the remote in the steering column. It started with remote in steering column.
i only use one remote and assumed that the other would work, tried it, no go. Changed batteries in both and both work just fine now.
Fwiw, mine is three years old, an early 2016 model.
Old Sep 17, 2018 | 10:06 PM
DSOMDream's Avatar
DSOMDream
All the batteries in the early 2016 cars must be going at the same time. Just replaced mine last week. Paul
Old Sep 21, 2018 | 03:27 PM
2019 ZR1's Avatar
2019 ZR1
So I put new batteries in both remotes and I still have the same problem. It will start eventually but not like it should. No other problems with the car so I don't think it is the battery. The battery gauge is reading 14 something. When I push the start button it takes a few seconds before it starts when it actually starts. Looks like it is going to have to go to the dealer..
Old Sep 21, 2018 | 03:47 PM
badhabit_wb
I ended up replacing the battery on mine as well.
Old Sep 21, 2018 | 04:23 PM
feeder82's Avatar
feeder82
Might not be relevant, but my 16 Malibu had this issue, there's a service bulletin on this issue. Dealer replaced the fob receiver and flashed a update. That fixed it.The dash should report a low fob battery
Old Sep 23, 2018 | 03:28 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Battery gauge reads alternator output, doesn't tell you anything about the car's battery. Get it load tested, most auto parts stores will do it free.
Old Sep 25, 2018 | 09:41 AM
Bill Dearborn's Avatar
Bill Dearborn
If you suspect the battery the first thing to do is to check all of the battery cable connections to the battery to make sure they are clean and making good contact. I have seen a lot of batteries replaced that didn't need to be replaced because people didn't make sure the battery posts and cable connectors were clean and making good contact. A car's electrical system is low voltage/high current and small amounts of resistance in the circuit can lead to large voltage drops where you can't afford to have them. Since the Corvette has a composite body all ground connections have to be checked as well since the body doesn't conduct electricity like metal car bodies do.
Bill
Old Sep 25, 2018 | 12:44 PM
badhabit_wb
Bill
I agree. Several of us have had battery related issues. Some were just loose wires. One was a new battery but the installer had failed to connect a ground correctly. My battery showed a good charge but when I replaced it all the issues I was having with codes went away. These are strange vehicles when the voltage is not correct.
To No remote detected
