DeWitts TOC/EOC Combination system
#361
So which coolant only version will cool best, or has the potential to cool best based on the airflow it will see?
#362
Former Vendor
The 2nd coolant only upgrade is the 1139114M radiator $839.99
A tie for 3rd coolant only (M7) is the 32-C7Aux $799.99 and not coolant only (M7) 32-OC 1199.99
#363
Sr.Random input generator
I'd also love to learn about my kit's ETA, but no pressure for mine; I'd rather wait until you're done : )
#366
Sorry Tom I should have been more clear. I specifically meant the original aux coolant only radiator, or the new aux coolant only radiator that you just drew up that is the same size as the two smaller coolers (oc/tc) ?
#368
Former Vendor
Still not real clear but I think you mean the first DeWitts version Aux coolant vs the new DeWitts version full size. That answer is "About the same".
atljar (06-21-2019)
#369
#371
Former Vendor
The new aux unit will have slightly less delta P and if properly exhausted will use a little more air than would have the original design but it's far from a free flow path. The stock unit is 26mm thick and this one is 38mm. So 50% bigger core with 50% more (thickness) resistance make it the same
#372
Were you able to sample 2017+ routing? Mine is a 2019; here's hoping it works bolt-on for 2017+, too.
Thanks for bringing out these kits! I'm sure many others who wouldn't like to cut their bumpers will also appreciate these kits. I know a few myself.
#373
Former Vendor
I was thinking we could just supply a length of hose and instead of going all round the radiator for the passenger side we could flip that fitting and go around the shorter path.
#374
Hey guys,
I have a 2014 A6 Z51. Will the 32-TO work for me?
The following 3 users liked this post by JCSIII:
#376
Former Vendor
The kit alone will not work if your car is stock. You do not have all the extra plumbing from the rear of the car to the front for the transmission cooler. Do a forum search for adding oem second front transmission cooler to your car.
#378
Former Vendor
he could do the 32 -OC if he didn't need to improve the transmission temperature.
#379
Tom, do you have an ETA on my 32-C7Aux?
#380
Former Vendor
