2018 with bent rims
2018 with bent rims
Was having tires swapped on a rear rim & the tech had me look at the wheel on the balancer. It was visibly out of round.
The car is still under warranty & there is no visible damage.
As an instructor, the car does see a lot of track time, but I am fairly easy on curbing.
Has anyone had their rims replaced under warranty?
Thanks.
Thanks.
Wow. I have heard of others complaining about how soft the OEM wheels are and how easy they bend. Not good to hear as a new owner. How would you know if you bend a wheel unless some one was balancing it?
Then when you take the car in to get the vibration checked out, meaning probably having your wheels rebalanced to see if it's off, the person doing the balancing will find out if they're bent.
But if your wheels are cracked, then you'll end up losing air pressure.
Thanks.
Thanks.
Z0HS1CK (10-06-2018)
For anyone who has experienced a Bent or Cracked Wheel, suggest you report to NHTSA.
Link Below:
https://www.corvetteforum.com/forums...afety-adm.html
Link Below:
