Before and After Dyno Results after Ported LT4 Supercharger
Is that because the porting is all before the lobes? If you ported the heads, for example, boost would go DOWN. But I guess if you're porting the intake tract, more air makes it in, hence more boost.
Supporting Vendor
Yes! 10% off EVERYTHING on our website including 103mm throttles, griptec pulleys, and of course, of CNC Supercharger porting Service.
www.kongperform.com
www.kongperform.com
Supporting Vendor
Exactly, our CNC programs optimize everything on the inlet side of the supercharger to get as much as in as possible, resulting in more boost, which in turn leads to the typical 45-50whp gain when combined with a 103mm throttle.
what are you guys running in the DMS trunk tank... meth or e85 or ???
tkddave (05-05-2023)
www.kongperform.com
www.kongperform.com
Will the 10% off return for Cyber Monday?
While I'd be naturally dubious, I once took a SECOND off a blown C4 in the quarter by improving a bad intake path. Intake losses on the intake side (or recovered gains) are multiplied by the supercharger.
Supporting Vendor
Absolutely insane results with a before and after at JMS Racing in Texas recently. The only changes between the two runs were the addition of the Kong CNC Snout and Supercharger porting along with a nick williams 103mm throttle. This is on a heads Cam LT4 setup.
If you are interested in getting your LT4 supercharger ported, head over to our site to get the ball rolling. We even offer custom formed foam shipping containers to send out in advance so you don't have to deal with the hassle of packing the supercharger yourself!
https://kongperform.com/products/kon...rcharger-snout
#33
Supporting Vendor
CNC Ported Supercharger by Kong Performance
DMS “Sw Special” camshaft by Texas Speed and Performance, LTD
CNC Ported LT4 heads by Frankenstein Engine Dynamics LLC
Flex fuel by DSX Tuning
DMS modified 95mm throttle body and pulley combo
DMS custom trunk tank
Kooks Headers and Exhaust
Roto-Fab, LLC
Tuned in house on our Mainline DynoLog Dynamometers using HP Tuners
Dyno notes: 3rd pull no ice down, 1200 FT da, 7th Gear, 80% Ethanol 17 psi
Roto-Fab, LLC
#36
Supporting Vendor
I know I’m bringing the thread back from the dead. Porting with no tune has become more relevant now with the emission laws as they are in CA. No tune allowed here. Has there been any further testing on what else can be done in addition to the porting? Does anyone know what tb or intakes work well in combination without a tune and not throw codes? I do run an x pipe catless even though I’m in CA and that would stay (don’t think they will catch me on that). Anyway, looking to do as much as I can and still pass smog. Idk if the NW TB requires a tune? I’m guessing yes and if so not much sense in porting the snout right? Might as well only order the porting for the supercharger then? Any additional info for us CA guys would be appreciated. I have also been considering the catless down pipes and swap back at smog time but idk if I could do that and a porting? Any one do try that on a stock tune?
#38
#39
This may aggravate some when I say this. But if you keep the stock intake and stock manifolds on the car, the ECU can handle a ported blower and even a 2.38 upper. As an FYI, the X port blower loves to be over spun. If will feel a little sluggish down low on the stock pulley but it will hit much harder up top.
#40
Looking at the curves in post #1, it doesn't look like the ported s/c is giving up anything anywhere. The increases in area under the curve for torque and horsepower is pretty impressive. I suspect the car was somewhat quicker after the port job, and really felt good from 4k up.
Thanks for bringing this thread back. I'd posted this very question in the performance/supercharged, etc., forum a week ago with no responses and this gave what I needed.
As I understand the information in post #39, I should be good on the stock tune (2016) with no other changes made to the car.
