Which 20 inch drag radial are you running?
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
It has come to the point where I can no longer run street tires. The Nitto Invos will just not hold above 3k RPM. What DR are you running on the street. I need something that will fit properly on a 20 x 12 rear as I dont want to run my 18/18 drag pack all the time. Thanks
Cajun @ Edgyvette (10-16-2018)
I must be dreaming this up.
Former Vendor
I haven't seen anyone else post this so i must be dreaming when I feel more grip from the rear tires since I added the DCS shock controller which seem to allow some squat on the rear and some front lift for more weight bias on the rear thus more traction.
Looking to see what people are running on the street in these cases. I have seen some running 18s with the Toyos on them. Feedback from anyone?
I don't know of a 20" tire that will do what you are wanting it to do. I've changed from 20's to 19's on the rear and use 325-30-19 MT DR's. I'm sure that going to an 18" or 17" would help a little as well.
Z06
The repro Z06 12X19's will handle the MT's just fine. That's the combo I use. I used to use Nitto NT05R's but switched to MT recently.
The following 2 users liked this post by Thomasmoto:
Cajun @ Edgyvette (10-16-2018),
vettejohn1969 (10-11-2018)
Anyone running THESE
Jason
Yes, except I have a 325 not the 315 like the link shows. Only have a few hundred miles on them, but love them so far. I’m on basically stock power (just a CAI) though. First gear you can almost give it 100%, but not quite and second gear hooked up at all times at WOT (in about 80 degree weather).
Jason
are you running them in the rear only or all 4?
HCI C6 Z06 here. My MT ET SS 325/30-19s hook up well, but start to get scary at 140-160 MPH. I was going to run tham at Mojave but after a couple of 1/2 mile events, no way I want to go faster than 170 on them.
