Lift for standard home garage
I have been looking on the forum at different lifts (2 post lifts and 4 post lifts) and wondering if I could put one in my standard two car garage. I have a 12 foot ceiling in my garage, not looking to stack cars, just a lift to work on my 2015 Z06 and wondering if a 2 post or 4 post lift would allow me to also park a car next to it. What is the measurement in the width once you have it installed? Also looking at some of the portable lifts that are out there. Any advice or feedback would be appreciated.
If I had a wide garage I’d be ok with two posts presuming I could open the doors all the way. If not, 4 post.
Have had a 4-post lift for many years now. Great for car storage, changing oil, lifting the car to a desirable height when detailing, and anything else underneath. However, for brake work and anything with the wheels/suspension, you will need some way to raise the wheel off the deck. Folks I know use this device: http://www.directlift.com/Pro-Jack-3500-P45C18.aspx. Turns your 4-poster into a more useful garage appliance. In my case, I also had to install a high-lift door. As for measurements, all the manufacturers can provide the info you need.
with a 12 foot ceiling you definitely have a lot of choices, I have an eagle 2 posts lift in my garage with a 9 foot ceiling. You should check out on the eagle lift very reasonable price delivered to your house
Received 4,552 Likes
2016 C2 of Year
2015 C3 of Year Finalist
My ceiling height is only 11 feet and I'm fine stacking cars and working under a 4 post. You will have no problems with height. As far as width, the 4 post really doesn't extend too much wider than the car itself.
I really prefer the 4 post. Much easier to get a car up in the air without crawling around on the ground to position the telescoping arms of a 2 post. With a sliding jack tray, you can do wheel work with a 4 post. Great ofr stacking cars as well.
intensifi (10-13-2018)
Garage has an 18' wide door--really helpful because lift is actually iside the garage centerline and still has 22" on the side.
Is there a difference in concrete garage floor depth requirements between 4 post or 2 post ? This could be a good solution for my winter storage . What is the height of a C7 on lift . C7 I think is around 49 inches high and is track and frame of lift plus 5 inches. Trying to see if a 4 post would work for me. Ceiling height is 10'6 and want to store Serria pick up 76 inches under Corvette during winter. 76 + 49 + 5 = 130 divided by 12 =10'8 . Might have to raise ceiling a foot or at least where roof area of Corvette meets ceiling. What are your thought on my solution. Thanks Dave
Received 8,928 Likes
If you want something to lift the car so you can do maintenance on it then the best thing is to purchase a lift that sits under the car when it isn't being used. A mid rise scissors lift can do that but they can put a lot of stress on your concrete floor. They support all the weight on one long cylinder in the front and two 3 inch diameter, 2 inch wide wheels in the rear. If you think about the pounds per square inch being applied where those 3 contact points touch the concrete it needs to be strong. In my last house which was 30 years old when I added a scissors lift the two rear wheels left very shallow but visible grooves in the concrete where they rolled back and forth for about 10 years.
However, there are scissors type lifts that don't involve rolling wheels touching the concrete. They are more expensive but may provide what you are looking for.
Here is one that requires some garage modification: https://www.gregsmithequipment.com/FM9SL-In-Ground-Lift?
gclid=Cj0KCQjwr4beBRDNARIsAGZaZ5cgEcC9u4 uIqzEXxlc6s3WpfRFou2xeBGRcW1tX8FAPnjuRDJ A-xlcaAq2UEALw_wcB
Here is one that may work on your current garage floor: https://www.gregsmithequipment.com/A...0aAiPoEALw_wcB
These are examples of what I am talking about. There are others available with different prices and ones that only rise 4 ft (mid rise) but they can make it easier to get a lift in a narrower garage (18 to 20 ft wide). You are not limited to a 2 post or 4 post solution.
Since I do my own wheel alignments I would really like to have this lift which includes a wheels free lift on top of the ramps. However, since I only do alignments twice per year it is an over kill.
https://www.performancetoolcenter.co...els-free-jack/
Bill
Borntorun04/17 (10-13-2018)
2016 C2 of Year
My understanding is a minimum 5 inch thick concrete floor is required for a 2 post as it must be bolted in. 4 post can be left free standing, as mine is.
Bill Dearborn, Thanks for response you bring up a good point with space with garage wall and parking other vehicle on other side of garage . Scissor jack won't work for me as I mainly want lift for winter storage but would get one with removable drip pans so I could do some maintenance if I chose too. Just measured garage floor is 19 .6 wide and garage door is 16 foot wide. I will have to go on lift web sites and get more info. I am/was trying to talk wife into agreeing to add on to garage on lets just say it's not going to well. (LOL) Lift could be a good solution.
Thanks for info. Just thinking sense reading thread today. Would a 4 post be better for winter storage over a 2 post . Thinking 2 post wheels and suspension won't have any support during 5 month storage. I have nothing above garage ceiling so I could raise ceiling to get enough space. Just looked in attic and the side of garage where Corvete is parked ceiling goes up on a angle and could raise it be raised 2 or 3 feet. Will check the lift web sites to see if they make a 4 post lift with enough clearance under to fit a Serria PU. Thanks Again, Dave
Dave, my ceiling height is 11 feet and I can't fit my GMC Sierra under it. Cars are fine, but no way with the truck.
My ceiling is 10’ 9” ... 8” concrete slab ...2 post Atlas lift with no issues over 3 years now. I also have no issues with putting full Trucke/SUVs on it and working under them (I use roller seats).
My ceiling height is only like 10 feet if that and I can get 1 car under as long as it's not a SUV. Be careful and check where the lift is made I wouldn't buy a Chinese made one.
Borntorun04/17 (10-14-2018)
2 post or a quick jack work great for home use. When I was shopping for a house in Gilbert, I didnt see a single one with a garage large enough to have a full size lift. I had one at my last house. The other thing you need to be careful about is the slab thickness and post tension cables if you have a post tension slab which most houses here have. I have a max jax and a quick jack. Both work good depending on what I'm doing. Your more than welcome to come over and check them out.
I have a two post asymmetrical Rotary lift. The lift post had extensions (it is 15' lift) that I simply unbolted from the top so that I could install in my garage that has 12' ceilings. I cut holes into the sheet rock for the pistons to travel, had to go into the attic to make sure it wasn't under the trusses prior to installing. I also placed the safety stop bar back on top of the lift post by making some brackets out of 1/4 steel plates, then bolted them in place on top like the extensions had. I gained an extra foot of clearance by relocating the garage door opener off to the side as seen in the pic. This garage door gets daily use, and for 10 years it has worked just fine in case anybody is wondering about whether or not relocating the garage door opener/motor was an issue. Four post do not work well for working on cars like engine or suspension removal. They are good for storage and as a service rack for oil changes and that is about it.
Not sure why my pic attachments are not uploading. PM me for pics until I figure it out they are jpg too.
Received 1,817 Likes
If a two-post is used for storage, and the car underneath is used frequently, there can be difficulties getting in and out if the two posts don't allow the doors to open very far.
Borntorun04/17 (10-15-2018)
