MTI Aux Fuel Sytem Test Video
WS6JJP (11-15-2018)
Cruise-In IV Veteran
Appreciate the testing and more importantly showing us the test results. I also like how you mounted I proved my mounting location being higher than the pickup tube is just fine. My fuel pressure on ethanol running 18psi with my F1A-94 + 103mm G1Pro + Katech is not dropping one PSI in 4th gear and holding a steady 11.7/8 air fuel ratio (ethanol) and 12.1/2 93 octane. So crucial getting fuel to these cars and it's not that simple either!
Received 1,817 Likes
Would you describe this fuel system in detail please? All the video shows is a light turning on when the load increases somewhat. Does this indicate turning on a second fuel pump, putting more juice to the original fuel pump, or what?
Former Vendor
Thanks,
Billy
Former Vendor
Billy
