New best 9.754 @ 143.51
Great run NicD, tell us about the CPR Stewart intercooler pump upgrade. Did it help with recovery of the MAT? Easy to install or needed to beef up the electrics and improvise a bit to fit? I am running the 80mm with 10% lower, boost is 15-16psi, no cat with 1 7/8 and 103mm. I think meth is need for full potential.
Originally Posted by NicD
4K so make sure you crank up the resolution since it usually doesn't do it by default!
Well a 15" rear conversion would definitely help a bit and help it hook better in tougher conditions for sure and I'm spinning the tire on the rim a solid inch or two every pass on this right now. The top end charge is ridiculous and far exceeds what the factory blower is doing for sure. For the mods I'll list them all below...
Magnuson TVS 2300
18% lower
NW 102mm TB
E50 flex fuel
Meth injection
CPR heat exchanger tank
CPR heat exchanger
ARH 2" Headers, no cats, factory catback
CAI
MT ET Street Rs on Forgeline 18s
Poverty Star skinnies up front
Magnuson TVS 2300
18% lower
NW 102mm TB
E50 flex fuel
Meth injection
CPR heat exchanger
CAI
Supercharger replacement
We had another private track rental out at Tucson Dragway yesterday and I took the C7 Z06 back out after some minor changes to see if I could set a new best. I added the larger Magnuson snout on the 2300 and the Nick Williams 102mm TB as well as CPR's high flow Stewart intercooler pump upgrade setup. I got a new best 60', new best ET, and a new best MPH that is just screaming fast for a stock engine with all of the "bolt ons" so to speak. Yeah I know the TVS 2300 is a grey area as far as being called a bolt on but it literally bolted on and just replaced the factory blower with no fuss so... The new best 60' was a 1.355 but it was actually .001 slower than my new best ET. It was pretty much dead hooking but would unload the rear tires just a bit on the 1-2 shift so I was playing with tire pressures quite a bit to see if it would help and it made some minor improvements throughout the day. The fastest pass was at the end of the day when the DA was reaching 4300 ft, I could not imagine what this thing would run at a negative DA track. And yes, I am pushing this thing hard and am at the very limit of the factory fuel system even with meth injection but ran it like this all day long and made tons of passes. The funniest part is that I finally made my official NHRA Level 6 Sportsman 7.50-9.99 licensing passes in this thing so now I don't have to dodge the track officials as much as before.
I'll have video later when I get a chance to process it but here are a few pictures...
The stock blower is certainly limited compared to the TVS 2300 but the stock blower is still pretty good when ported. All depends on how far you want to go.
I am porting the stock blower & snout so we shall see. Don't expect you're results but hope for low 10's.
Supporting Vendor
9.49 @144x to be exact not that we have the stock blower record or anything haha.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
rflow306 (11-28-2018)
