Tony Mamo Throttle body
My first C7 was a 2016 M7 Z06. The low end throttle bog, in my opinion, was terrible and in some instances, it felt unsafe. I did wind up purchasing the ported throttle body from Tony and it did improve the throttle reaction time and minimize the low end bog....but I still could feel it. I wound up selling that car and buying a Challenger Hellcat with a 6 speed manual transmission. Zero bog on that car and it wasn't because of the engine horsepower...it was turned that way from the factory. Well, I missed my Corvette and just bought another left over 2018 Z06 with only 2 miles on it....and it's an A8. I had it delivered to my home in an enclosed trailer and my only driving was to pull it into my garage. The engine was cold, well below operating temperature, but when I shifted it into D, I could feel the same low end bog as the 2016 had, creeping into the garage.
Now, I bored every one with this story, but it sounds like I have another Mamo polished throttle body in the near future and I was looking for some more feedback with regard to it's effectiveness in an A8 car, although Rogergcam from the C7 Forum, seems to give it high praise. Any other comments?
Edit Quote Multi Quote Quick Reply
Reply SubscribedQuick Reply
Source
◢Auto-Saved
To view/manage your attachments, click "Go Advanced"Options
Quote message in reply?
Back to SubforumC7 General Discussion
View Next UnreadOEM tires
Quick Reply Reply Share
Forum Jump
(no links set)
Edit Links ...
Corvette StoreC7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored AdsVendor Directory
Contact Us About Us ArchiveAdvertising Cookie PolicyPrivacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated
Source
◢Auto-Saved
Forum Jump
(no links set)
Edit Links ...
Wheels & Tires
Thanks Dennismur & RegnaR, it sounds like you have the recipe. Where did you get your BMS filter?
You should look at throttle controllers. Get more linear input through the pedal
Received 2,379 Likes
this is tuned into the ecm and can be fixed easily with a tune. the TB is not the problem although people do often report it helping mask the true issue. if you don't want to tune then obviously TB and filter, etc are the only way to help.
Higgs...glad to see you're still around. I'd do the ECM reprogramming if there was a "mild" programming that wouldn't be likely to cause an engine problem. The thought of losing the engine warranty because of a mild twist during the New Car Warranty period, is frightening. That's probably an impossible question to answer but if there's a way, you probably know it.
IMO helps stumble/stalling on M7, not needed on A8
Here's my take. I have tried ported & the larger stock ZR1 95mm TB on the C7/Z06 A8 and also some high flow air filters (Green & BMS) in the OEM air box. The ported or larger TB made no difference at the track compared to the stocker in the 60ft or 1/4 mile. On the street with an A8 if you want to accelerate faster just give it more throttle.
Where I did see improvement from stock at the track was with the high flow aftermarket OEM replacement air filters i.e. the Green and the BMS and also the AFE CAI with the low flow dry air filter.
Both the OEM ported & 95mm TB w/spacer are now sitting on the shelf.
This is the OEM ported with the machined down throttle shaft & added additional porting.
jstewart (01-02-2019)
The Mamo PTB fixed my throttle lag by at least 75% on the stock tune. Huge improvement.
I am now modding and tuning, and will be selling my Mamo PTB soon... should be ready within 2-3 weeks.
The xpipe and PTB, best 2 mods you can do to your manual z06, IMHO.
I would do a tune on my car, but if i did that, might as well throw more mods on it like a pulley, long tubes etc. But it's already too late in my ownership as i wanna move on to the next beast. So gonna keep it the way it is.
FYI: from what I have seen on the net you can save the $50 for the ZR1 TB adapter/spacer. You only need to drill out the holes in the ZR1 95mm TB larger until it mounts to the supercharger snout bolt pattern. I would drill the 4 mounting holes in the ZR1 TB out going a little larger on the drill bit until the TB mounts up. After porting out the snout of the supercharger for the larger TB there won't be much sealing surface left so 'I' would smear a very thin layer of the "Right Stuff" on one of the mounting surfaces just before bolting the throttle body on. Being its only vacuum at that connection a thin smear of the rtv sealant should do just fine.
Final work is done with the ported Mamo 95mm TB installed. Stock blower and snout ported by Weapon X. My opinion if you are going to use a 95mm TB you must at a minimum match the TB to the SC snout (smooth transition) either by port matching the adaptor & snout, or as C7/Z06 man suggested mounting directly to the snout. I had my snout ported for a 103 mm TB if I want to go there later & had the adaptor ported for a 95 mm X 103 mm transition.
FYI: from what I have seen on the net you can save the $50 for the ZR1 TB adapter/spacer. You only need to drill out the holes in the ZR1 95mm TB larger until in mounts to the supercharger snout bolt pattern. I would drill the 4 mounting holes in the ZR1 TB out going a little larger on the drill bit until the TB mounts up. After porting out the snout of the supercharger for the larger TB there won't be much sealing surface left so 'I' would smear a very thin layer of the "Right Stuff" on one of the mounting surfaces just before bolting the throttle body on. Being its only vacuum at that connection a thin smear of the rtv sealant should do just fine.
Agreed, but my main reason for using the adapter was to match the 95mm TB to the SC snout which I had ported out to 103mm. I was thinking that would match up to a larger TB if I wanted to go that way later without having to remove the SC later. Right now I don't think I will go any larger because the car is already making more power than I anticipated.
