C7 Z06 vs C6 Z06 - My definitive position
#121
The C6 ZR1 is the car to compare to the C7 Z06 both supercharged.
I have owned both ZO6s C6 and C7.
z51vett
Doug
z51vett
Doug
#122
Z0HS1CK (01-30-2019)
#124
#125
How slow is it on upshifts at wide open throttle? That is when it counts. Part throttle instant shifts are non interesting. I only hear people complaining about upshift times when they are driving at part throttle. Very few ever have the cajones to hold the pedal to the floor long enough to get any wide open throttle upshifts. As far as downshifts as long as they are the same speed as somebody shifting a manual transmission and predictable that is sufficient. Previous transmissions weren't very predictable when the shift would happen. On the C5 and C6 there were times when a driver would initiate a downshift at a particular point in the braking zone and the transmission would sometimes downshift as soon as the shift was initiated and sometimes it wouldn't downshift until after the driver got back on the throttle exiting the corner and the sudden downshift at the wrong time would break the rear wheels loose and spin the car. If the timing is always the same then the driver can predict where the downshift will occur and plan accordingly.
Bill
Bill
Are you suggesting that you either are using 100hp OR 650hp when driving your z06? And nothing in between?
If you're merging on the highway, or want to pass someone, is the only option is to go WOT? Like you said, you need to have cojones to go WOT in our cars, even in the best of road conditions. Why wouldn't you want a faster shifting trans that shifts fast, idk, all the time???
Why would i want a trans that sounds/feels/is sluggish in any other time other than WOT?? That makes zero sense to me.
That's why DCT's are available. If gives you that sense of urgency, ALL THE TIME. It's the best of all worlds. Fast when you want it, and still fast when you don't even need it/think about it.
If the suggestion is that fast shifts at ONLY WOT matters most, then every Z owner should just convert their car to a dedicated drag car. Because that's what it seems like that's the general consensus. Who needs to drive their Z on the street if fast shifts don't matter and not everyone has the ***** to go WOT anyway. Might as well just not use the car on the street.
R&D (03-27-2019)
#126
C5 was solid improvement over the c4
c6 was better - actually a considerable improvement.
C7 - more technically advanced with bells and whistles but more technical is not always better. It was a sideways move at best over the c6. The B team was working on the c7 project while the A team was assigned the c8.
I am hoping the c8 will be a big step up seeing how the A team is on that project.
#127
C4 was a big step up from the latest versions of the c3 on handling and performance especially the c4 zr-1.
Even the 6th gen ZL1. How come that car was engineered better than our z06's??? Our cars do look better for sure but camaro guys were lucky with that car. It's an incredible machine.
Can't wait to see the C8 already.
#128
#129
@BrunoTheMellow Maybe you're not familiar with Gizmo, but he's a real C7 hater and you'll never convince him it's better than the C6 in any way, and if he does say one particular aspect is better, it will be a trivial one and he'll attach a caveat with it. No point in wasting your breath.
#131
Moderator
I remember back in 82......
#132
Tony , the first 2 comparisons (interior and exterior) were very good. How is the 3rd comparison performance (stock c6z versus stock c7z) coming along?
#134
#138
https://www.youtube.com/watch?v=-QwcgOX5AbQ stock c7z 178 mph texas mile – k&n intake.
https://www.youtube.com/watch?v=qY0ox4bgOn4 stock c7z 157mph texas mile
Try again.
#139
Zackly. But Gizmo HATES his C7 so he has rose colored glasses for the C6. You could show definitive proof that the C7 is better in literally every way (not saying it actually is, but IF you had it) and he'd be like "but, C6..."
#140
Received 8,918 Likes
Why would only full throttle shifts matter?
NO
I have an M7 and when I want to pass I use the throttle and don't downshift. The engine has sufficient torque that there is no need to downshift when driving in 4th, 5th, 6th or 7th. There isn't any SUV, CUV or sedan that will cause it a problem. If somebody wants to speed up to keep me from passing I just add more throttle. Now if I am in a passing situation on a two lane 55 mph speed limit road with a car going 45 mph in front of me I will downshift by pushing in the clutch and moving the shifter to third when I see the potential opening ahead. As the vehicle heading in the opposite direction clears the car in front of me I am on the throttle and heading for the gap between the two and will be wide open while passing the other car to get back into line ASAP. I like to limit my time in the kill zone. Now if I can dawdle around with a manual shifter doing that why worry about a faster but acknowledged automatic that shifts slow at part throttle? There is no need for the big roar in most passing situations.
Mainly because the sudden torque change that comes with an automatic downshift can way too much for a normal or even an inexperienced driver to handle. The only thing the downshift needs to be is predictable. It may take 3 seconds to shift but if I know it is 3 seconds every time that is all I need.
As I said before if you are at part throttle you aren't serious about performance and that doesn't have anything to do with drag racing. If a person can't drive an automatic like a manual which means paying attention to what is happening ahead and planning when to down shift before the opening occurs they really aren't involved in the car and can't really be all that serious. I take it you don't use the paddle to downshift until it is time to pass Vs being prepared like you would be with a manual transmission. Planning ahead means you don't need to have a fast downshift and a lazy upshift because the pass is over and you are already breathing off the throttle. Now when you are on a track where your intent is to get to from one corner exit to the next corner entry as fast as possible you don't want a lazy shift but again you are wide open because if you aren't wide open you really aren't serious about getting there as fast as possible.
NO
