Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 Z06 Discussion
Reload this Page >
Curb rash on the front air dam; it was bound to happen
Old 01-08-2019, 05:07 PM
CF Senior Member
Default Curb rash on the front air dam; it was bound to happen
No matter how careful I was....I knew it was gonna happen sooner or later. I just lightly rolled into a concrete curb while parking "head in" into a parking space. Slightly scuffed up the tip of the stock black plastic Z06 (not Z07) air dam. Air dam not broken or misaligned, but the scuffs are visible. My options seem to be:
1) Forget it and live with it;
2) try to repair it a simple and easy way; or
3) replace the air dam.
To attempt #2, my thought would be to sand down the scuffed part...but then the sanded part would be even more visible. I could try to "blacken" with tire black, or with something like shoe polish, or paint it. For all the hassle of painting, I would probably just replace it.
I figure 90% of Z06 owners have similarly scuffed up their air dam. Any genius ideas for hiding minor curb rash? Or are #1 or #3 the only real options? I don't need it perfect, but I don't want it to look like a redneck/ghetto repair, either. If #3 is the only viable option, can anybody recommend a good vendor (other than Chevy dealer)?
(if anybody is offended by the "redneck/ghetto" adjective, lighten up)
6104696 is offline
Old 01-08-2019, 05:34 PM
MickOpalak
CF Senior Member
MickOpalak's Avatar
Forget it and live with it. Front splitters like that are basically disposable. When it gets so beat up that you can't stand the sight of it any longer then go with the replace it option.
MickOpalak is online now
The Following 3 Users Say Thank You to MickOpalak For This Useful Post:
fpfaeth (01-10-2019), rogergcam (01-15-2019), ZR1Bob (01-09-2019)
Old 01-08-2019, 07:21 PM
Greg00Coupe
CF Senior Member
I’d take some tire black or vinyl coating and see what that does. If thay does not satisfy you sand it, I actually use a fine file and redo with a coating.
I’ve hit mine a few times and I’m good with the repairs.
But I’m not **** about details. My saying is if you need to squint to see something it’s not there. Don’t go looking for issues if they are not readily eye catching. Also if I am the only one that can notice an issue I don’t get too excited over it either.
I don’t sweat the small stuff makes the car more enjoyable for me.
Greg00Coupe is offline
Old 01-09-2019, 02:00 AM
TKgs2010
CF Senior Member
Exactly why I never pull forward into a parking space, truck driver mentality I guess.
TKgs2010 is offline
Old 01-09-2019, 09:31 AM
timmyZ06
CF Senior Member
timmyZ06's Avatar
No front camera? Ive been down that road!!! Mine was a stage 3 carbon flash. i had it repaint, costed me 150$ was like new afterward!
It was on my 15, now the 19 will have front camera!!
timmyZ06 is offline
Old 01-09-2019, 10:04 AM
Range_Rat
CF Senior Member
Range_Rat's Avatar
Consider it as essentially a wear use item (like brake pads). Give it your best shot on repair, and see how that works out for you. If it's a no go, just order a replacement. Relatively low cost, and straight forward replacement.
Range_Rat is offline
Old 01-09-2019, 12:54 PM
fjaphd
CF Member
Default cure 4 road rash
Go to a 3 m dealer and have them install a faux carbon fiber tape-looks great is cost effective and completely covers the rash. I've done it twice!
fjaphd is offline
Old 01-09-2019, 03:23 PM
MMD
CF Senior Member
MMD's Avatar
Maybe you can explain how using the perjorative term "redneck" differs from say using the offensive deragotory "n-word" term?
MMD is offline
Old 01-09-2019, 04:18 PM
dar02081961
CF Senior Member
If it is really bothering you just replace it.
Its not cheap but $160 is worth having it look new.
https://www.ebay.com/p/C7-Corvette-S...2352/670952072
dar02081961 is online now
Old 01-09-2019, 04:38 PM
DogTag-C7R
CF Senior Member
DogTag-C7R's Avatar
to each their own -for me - It would drive me Bat **** crazy and for the cost - I would put a new one on there - do the labor yourself. then its over with.
DogTag-C7R is offline
The Following User Says Thank You to DogTag-C7R For This Useful Post:
JAYNO20 (01-09-2019)
Old 01-09-2019, 04:46 PM
JAYNO20
CF Senior Member
JAYNO20's Avatar
This is exactly me. I have the stage 3 front lip and it is scraped on the under part of it where it ISN'T visible at all but even that bothers me a little bit...
JAYNO20 is offline
Old 01-09-2019, 05:11 PM
RegnaR
CF Senior Member
RegnaR's Avatar
I threw out my state one splitter when I got a stage two one. You should be able to find one pretty cheap for sale.
RegnaR is offline
Old 01-09-2019, 06:02 PM
Cercone
CF Senior Member
Cercone's Avatar
History? Now get out of here hillbilly! Haha soo sensitive these days...
Op I went with the Protect protection plate. It helps against underneath scrapes but if you hit something square in the front your probably still gonna have visible damage. I find the camera slightly difficult to use.
Cercone is offline
Old 01-09-2019, 06:38 PM
hummiscorvettetaken
CF Senior Member
hummiscorvettetaken's Avatar
Option #1 and call it Patina! - the only way to keep them showroom fresh forever is to just leave them parked at home away from all hazards
hummiscorvettetaken is offline
Old 01-12-2019, 10:34 PM
ONEBADZ
CF Senior Member
Support Corvetteforum!
ONEBADZ's Avatar
Not offended at all but this “Redneck” has front cameras so after 2 years mine still looks new.
ONEBADZ is offline
Old 01-13-2019, 10:18 AM
salcolkat
CF Senior Member
salcolkat's Avatar
I replaced mine myself $150.00 on line and 30 minutes to change it. Came with instructions. You just need a drill and pop rivet tool.
salcolkat is offline
Old 01-15-2019, 02:42 AM
CF Senior Member
Front camera works fine. Car was already parked; I was in a rush, pushed in the clutch a half second before hitting the brake and starting the car. It rolled forward about an inch...and that was enough......
Interesting.
OMFG. First step: Lighten up. Second step: Take some history lessons. Third step: Learn to spell. LOL. (hey, that rhymes)
6104696 is offline
Old 01-15-2019, 07:54 AM
Warp Factor
CF Senior Member
Warp Factor's Avatar
Wow, I guess some people are really desperate to be offended somehow!
For me, "hillbilly" and "redneck" can be expressions of fondness. Why would you assume that they must be pejorative? Now go back to starching your underpants.
Warp Factor is offline
Old 01-15-2019, 09:26 AM
Toddiesel
CF Senior Member
I'm on the "replace with a stage2/3 splitter and while you're at it, get the grille with cameras" band wagon. The grille isn't a terribly hard install. I did it myself in my garage when I had a stingray (HATED the "braces" grille and swapped it with a Z06 grille). Took me less than an hour and I'm far from a pro.
EDIT: just saw your post #18. Was a little buried in quotes so I missed it. If you've got the cameras, I definitely say just take this opportunity to get a stage 2/3 as it looks WAY better. You can pick up an aftermarket one for super cheap. Like $500 for carbon flash.
Toddiesel is offline
Old 01-15-2019, 09:33 AM
Toddiesel
CF Senior Member
Do NOT do this. Nothing looks cheesier than fake carbon fiber. People see it and say "oh you got the carbon fiber lip, nice! I like me some carbon fi--- wait... that's hydrocarbon. oh... *awkward silence*" It's like seeing someone's really nice engagement ring and then learning it's CZ. womp womp.
Quick Reply: Curb rash on the front air dam; it was bound to happen
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
