People who DD their Z...
3 best things:
-Car is perfect when daily driving. Not even any real issues in snow (ground clearance is the only limiting factor assuming you have snow tires)
-The power - it really changes your driving style. I find myself being alot more relaxed/chill driver, because i know i have the power to overtake anyone weather they want to allow me or not :P
-The dealers assume the car was a garage queen and never winter driven when you try to sell it lol
3 worst things:
-Tire wear - i had to switch to non-runflats. The stock tires lasted literally 6k miles with normal street driving.
-Slight fear when driving on unfamiliar roads/garages. The bumper design is pretty good even when fully lowered. But there will be cases where you will scrape.
-My main issue has been with the A8 transmission tuning during normal street driving. I wish there was a setting to keep it in "performance shift mode" all the time.
3 worst things:
3 best things:
-being able to pass anything anywhere (like when a truck is going 15 under the limit on a windy road and you only get like 30 yards of dotted lines to pass at a time)
-the looks/thumbs up you get
-makes commuting a little more bearable
3 worst things:
-tire wear, for sure
-have to be VERY careful of speed bumps and other types of road hazards that other people can just ignore
-driving in the rain can be iffy on roads that have poor drainage
3 worst things:
I don't daily mine in the winter but still try to get it out at least 2-3 times a week if the weather is decent.
3 best:
- never a spot I can't fit the car, be it in traffic or parking
- fun factor is off the charts
- decent amenities (3LZ anyway) and a cockpit that's nice to be behind
3 worst:
- my own fault 100% but, going with catless exhaust was a huge mistake....the smell! ugh
- not a quiet cockpit, even in stealth mode there is a ton of road noise (will be fixing this with sound deadening material this summer)
- no matter what tire you run, these things are nail/screw magnets!
- bonus 4th gripe....I am NOT a fan of the standard seats. Hits my thigh in a weird way and I kept hoping the seat would "wear in" but after 11k miles, no dice. (over 6', under 200, so it's not an issue of thunder thighs...)lol
3 best:
3 worst:
I only bought my new 2019 Z06 in Dec. 2018. So it stored for the winter. Waiting for spring. A lot of different pros and cons here. But one I have not seen anyone mention not sure what everyone has M7 or auto. No complaints with all that power and shifting or wishing they had one or the other. I know from bringing my Z home and being used to my C5 Z06 6 speed it will take a little adjustment for the 7 speed. This was one of my back and forth on trying to decide which way to
go. Because this is a Pro or con. Depending where you DD your car it can be a real pain.
The cup holders are horrible lol, don't put anything in them and floor it or brake hard it'll go flying out the cup holder and if its a drink from a fast food place or something it'll spill everywhere.
https://www.ebay.com/itm/C7-CORVETTE...-/233121609877
One of our members developed this. Mine will be here this week and let you know my thoughts.
#35
Actually it’s a retractable piece that still allows one to close it. We all know the cup holders are to shallow. This should solve the issue. I’m not selling them. It’s worth it to me👍🏻
#36
Received 8,926 Likes
I don't daily drive my 15 Z/M7 but have some likes that are similar to others:
- Very flexible power delivery from off idle to insane depending on how much you depress the throttle. A slight tickle will have you pull away from the stop light faster than all the other traffic even if you are caught sleeping at the switch.
- Comfortable, the interior is pleasant to be in and the Comp Seats are great. The seat bottom cushion may feel stiff over a short drive but over longer periods of time it actually provides the support to keep your body relaxed.
-Tuneable Exhaust. Can have it loud in Track Mode all the time or if you want to have it quiet can put in Stealth Mode. With the M7 when the Exhaust is set in Permanent Track Mode it has wide open straight pipes all the time except when running in V4 mode. With M7s V4 engine mode is only available when the Drive Mode is set to Eco. What is great about the exhaust is even when it is open it doesn't make a lot of noise at part throttle but bring the throttle down to the floor and as the boost starts building the noise overwhelms the radio on its loudest setting plus the tire noise and even the wind noise if the windows are open. It is loud. You don't hear anything else. Even with helmeted mounted speakers and a microphone right in front of the lips the intercom is drowned out by the exhaust sound.
- Always and eye catching ride. This can sometimes be a downer since the attention being gathered can sometimes be too much. Of course that happens with a lot of Vettes and we all have to get used to the sight seers and posers that drive all around you and sometimes seem to want to crash into you.
Comment: Ease of Entry/Exit is fine if you have enough room to open the door all the way, make sure the seat is all the way to the rear and remember the rules for getting into all Corvettes since the C4 (84) came out. When entering turn around and face away from the car use your hand to guide your butt away from the seat bolster as you sit and sit down. Once down then swing legs into the car. Saves wear and tear on seat bolsters and keeps you from ripping the buttons off the rear pockets of your pants. Put leg into car first and you will screw things up plus have difficulty getting in. Even if in a tight parking spot and can't get the door all the way open remember Butt first.
Dislikes:
One: Tire Noise. No way around it. Like all other Vettes the rear tires are only about 30 inches from your ears with a thin sheet of plastic between them and your ears. The Michelins make a lot of noise on some types of pavement but I do a lot of track events and true race slicks without a hint of tread make a lot of noise as well.
Bill
Dislikes:
Bill
#37
https://corvetteclips.com/shop/ntwh4...6mu289u5-d32lk
