Sponsored by: GEM Motorsports
New PB 9.66@142.with a 1.7 blower no cam or heads
Old 01-21-2019, 09:48 AM
rflow306
rflow306's Avatar
Originally Posted by GhostBluZ06
what does this mean?
I broke my diff a while back and with the help of Lujan Motorsports and a few forum members was able to upgrade the diff. The factory diff has only two spider gears from the factory. I made close to 100 passes with this set-up before it broke the passenger side axle stub. So I just replaced those with the DSS 300m stubs.
Machined Carrier with the second pinion shaft hole.
4- spider set-up
Had to weld a bolt in order to get the factory stub out of the axle.
New DSS subs.
broken factory stub inside the axle.
Mikec7z (05-08-2019)
Old 01-21-2019, 09:54 AM
GhostBluZ06
GhostBluZ06's Avatar
WOW! Bro good info. Would this process be hard for someone wanting to do this ahead of time before breaking it? With that nasty launch I see why it broke LOL. An all that off idle is crazy.
Old 01-21-2019, 10:45 AM
FYREANT
I'm Batman..
Pro Mechanic
Support Corvetteforum!
FYREANT's Avatar
Originally Posted by rflow306
It's the four spider set-up and DSS axle stubs. lol
I thought the same thing lol
Old 01-21-2019, 10:47 AM
NicD
NicD's Avatar
Damn that's hauling the mail! I'm super jealous of that DA too!
Old 01-21-2019, 11:07 AM
rflow306
rflow306's Avatar
Thanks Nic. Anytime we see low 60's in the forecast for a test n tune we run to the track, lol. Your ride would definitely put down faster numbers with that DA without a doubt.
Old 01-21-2019, 11:58 AM
NicD
NicD's Avatar
I would run out the track every time with that DA if i was out there too LOL! We usually have anywhere from 4000' to 4500' DA when we run down in Tucson so our air sucks.
Old 01-21-2019, 03:58 PM
avtarv
avtarv's Avatar
What size upper pulley? No issues with heat?
Badass runs!
Old 01-21-2019, 06:22 PM
rflow306
rflow306's Avatar
Badass runs!
Thank you.
I have a 2.31 upper and 18% lower. I would not run this combo with-out a twin meth nozzle to keep the heat in check.
Old 01-23-2019, 09:55 AM
rflow306
rflow306's Avatar
It is just time-consuming as the center section needs to be taken completely apart in order to drill the second shaft. Speaking from personal experience it should definitely be done before you break a spider gear as that can sometimes take out the side gears and do damage to the carrier.
GhostBluZ06 (01-23-2019)
Old 02-14-2019, 09:49 AM
CamOnlyJabroni
CamOnlyJabroni's Avatar
I pretty much have the same setup as you only less boost. I’m hoping with just a 2.38 pulley wise and no lower with a JMS low side voltage booster I can get away with e50 no meth. Cooling wise I have Fasterproms thermal reduction plates, 160 stat and soon to be CPE heat exchanger. I’m interested in their 5” CAI too.
great times. Getting a lot of performance per dollar with what you have done. I’m trying to do something similar.
rflow306 (02-15-2019)
Old 02-14-2019, 10:26 AM
1fastC7
1fastC7's Avatar
Damn she moving out with those mods...nicely done
Old 02-14-2019, 11:36 PM
David4359
David4359's Avatar
Congratulations that’s moving for stock blower.
Old 02-15-2019, 01:36 PM
  #33
DRLC5
DRLC5's Avatar
Nice congrats bad *** ride.
Old 02-15-2019, 02:11 PM
  #34
rflow306
rflow306's Avatar
Thanks, the CPE heat exchanger and expansion tank are both quality products. I want to try their 5" Cai also.
Old 02-15-2019, 04:30 PM
  #35
Jim Barker
Jim Barker's Avatar
That was insane. Looks like you and the Mustang just hit light speed ( Look again it looks like he left early) Red Light
Old 05-07-2019, 11:01 AM
  #36
Gary Murray
Cruising
Gary Murray's Avatar
Where did you get the spider gear setup?
Old 05-07-2019, 07:02 PM
  #37
rflow306
rflow306's Avatar
Got it done by Lujan Motorsports in Miami.
Quick Reply: New PB 9.66@142.with a 1.7 blower no cam or heads
