Differential Fluid - When and how often???
Just curious to when everyone first changed the diff oil from new and how often after that??? Thanks!!
Received 2,379 Likes
changed my diff and manual trans fluids at 500 and will never change them again.
Received 8,929 Likes
No need to change them unless tracking the car. If tracking the car change after first event and after each 24 hours of subsequent track usage. Track usage dumps a hell of a lot more heat into the diff than street/highway driving. Your OM is correct when it doesn't show a service interval for the diff in the maintenance requirements. If you don't change the fluid the diff will last well past 100K miles just like millions of other modern diffs that are on the road today If you change the fluid you will get about the same lifetime.
Bill
Bill
Many of us changed early as there was a spate of folks that found out they had only partial fills in the diff and very loose fill bolts. I never measured my fill but clearly got out less than the 2.75 quarts that my measured fill in gave me. And yes my fill bolt was only finger tight.
I didn't change mine at 500 miles but i have 13k now.
I will change it in spring and that's going to be it. Because i don't think i'll have the car for more than 2 years from now anyway.
Received 4,558 Likes
2016 C2 of Year
2015 C3 of Year Finalist
My 2016 was full and the plugs were tight. I have no plans to do it again.
Z0HS1CK (01-22-2019)
Changed Diff at 5k miles and was expecting break-in material. Was clean as w whistle, glad I did it though. Now I will do the M7 trans sometime. At 8k miles currently.
I had the dealer (Criswell) check the diff fluid when I had the car in for the 500 mile oil change (2016). They reported it as slightly low and supposedly topped it off, no charge. I have no plans to change it or worry about it for the foreseeable future. 13K miles now.
I changed mine at around 2k and after my first DE event. I am planning on changing it every year, if I track the car.
Is it worth to do the manual trans fluid though? I heard even from factory it's good for 75-100k.
now I'm thinking if I should do it while I'm having the diff fluid done too.
2016 C2 of Year
Rob, if you aren't tracking it and you aren't having anything more going on than the typical, cold 2nd gear nibbles, I wouldn't bother.
Z0HS1CK (01-26-2019)
My rear diff was replaced under warranty at approx. 30K miles. After that I had all new diff, gears, axles and oil upgraded a while back. I'm at 64K now and will prolly change it again in 20K to 30K from now unless I find out differently.
