Halltech's 608 RWHP Carbon CFV Induction
Supporting Vendor
St. Jude Donor '09
Dyno numbers don't lie, especially when the dyno shop has no affiliation with Halltech. Here is a shop that put our bragging rights to the test. We lost to the AFE when our intake was dynoed with our ram air filter, which works best with our TRIC ram air system, but that system and normal filter was not in play on this dyno session. Coincidentally, the Green Agapostemon filter was used on the last dyno session which slammed all the competition badly. Maybe we should call the filter the"Punisher".
Check out the dyno here, but remember, in full disclosure, the shop tried their best to compensate poorly made intakes by adjusting the air fuel ratio through a tuning session. Our intake comes already tuned, so no further tuning is required for maximum performance. We have a system going out today with our TRIC Ram Air Induction. That system increased boost to 12 PSI on our 2015 C7 Z06. See HP Tuners below:
(We are currently backordered by three weeks-order now, since we shut off orders when we hit 4 weeks backordered)
Halltech TRIC Ram Air System
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
Was the AFE dry or oiled filter used in this test?
Supporting Vendor
St. Jude Donor '09
The first dyno below shows+45, but look at the air fuel ratio, stock-Halltech; virtually no change in the air fuel ratio.
The dyno below was done on a separate C7Z06 shortly after we launched the product. Joel's dyno was not available for some time, as he felt it was too good to be true. I actually agree, but the numbers are pretty spectacular either way. I suspect they had a blower type fan directly in front of the right port that we use for our TRIC Ram air system. Another customer saw +84 RWHP vs. stock with the same Stinger-RZ and TRIC ram air setup. I will search for that dyno/
The current dyno at the very top of the post was another dyno session by an independent shop that has no affiliation with Halltech. You might check with them to see the details of how they conducted their testing. There is nothing wrong with the AFE results. Both companies make spectacular products.
Jim Hall
Harbgrogan (03-15-2019)
Supporting Vendor
St. Jude Donor '09
The testing was against our synthetic filter, not our high flow, but it appears that the Green Agapostemon filter picked up +13 RWHP against the older Halltech filter.
Definitely worth the upgrade. https://www.halltechsystems.com/product-p/aga-608.htm
Supporting Vendor
St. Jude Donor '09
One more point
The filter used by the dyno testers was designed for better flow using our TRIC ram Air system. The design is more conducive with that system, and would suffer some loss of HP not have ram air.
The best setup for major power is our Stinger-RZ system, and TRIC RAM Air. All of our Stingers for the C7 come standard with the Female Green Agapostemon Bee filter. Female Bee? Yep, the female Agapostemon Bee is the only one with a Stinger; the male is subject to her whims.
