Meth and E questions
Old 03-13-2019, 10:58 PM
Tennispro1986
CF Senior Member
Default Meth and E questions
I am currently at 650 whp basically full bolt on. I want to run ethanol, but I know I will need meth as a fuel supplement. My question is, if I install a flexfuel sensor, how will the meth know how much to spray? The meth from my understanding is a stand alone system, so it's either spraying or not, correct? So lets say I fill up and the ethanol content is E40, how would it know to spray less than lets say full E85?
Tennispro1986 is offline
Old 03-15-2019, 05:28 PM
AZGASSER
CF Senior Member
AZGASSER's Avatar
You will need a tune for sure and I would not try to do it alone. My meth kit is set up based on reading from the MAF. Others do if off MAP. Either way, work with a reputable shop/tuner to get it dialed in. I also have a low side fuel system to make sure there is enough high side pressure/fuel. You need more ethanol to get the power so you may need this if you are going to run full E85.
AZGASSER is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
