Exhaust manifold stud part number please
Hi All, I was hoping to get some help with a part number. I have an 17 z06 with main cat delete. As part of the swap, I remove a couple studs to allow removal of the cat attached to the stock manifold. I replaced them with bolts but want to have studs to put back in if I ever swap back. I have looked for the part number on gmparts as well as numerous searches in the forums but haven’t found it yet. Anyone mind letting me know that part number? The ones I removed are messed up.
thank you in advance,
Bbgun
Bbgun
17 or 07? 07, you're in the wrong spot. thats called a C6
norcal ss is the fellow to ask
its been awhile here but i wanted to share this information for anyone looking
i replaced the OEM lower exhaust manifold stud with ARP part number "ARP Stainless Steel Accessory Studs 400-8019"
i bought them on Summit
https://www.summitracing.com/parts/ARP-400-8019
comes with 8 studs, nuts and washers. I haven't had any issue since install. i did buy new gaskets when installing high flow cats
EDIT
just so there zero confusion
im talking about these
EDIT
If youre talking about where the mid pipe connects to the primary cat pipe, these are what you want and theyre cheap. Worked for me on my Borla mid pipe install.
EDIT
EDIT
