Trouble with burnout at track
Took my 17 ZO6 to the track today and had trouble with burnout. Stepped on brake smashed the gas and it was like the engine was cutting out or weak. I do have ET Street R tires and the burnout box was pretty dry. I also tried it off the the track in parking lot and same thing happened. Car is all stock and the trap speed was 127 with terrible track prep 1.88 60’. Is this caused by the torque management system and stock tune?
No matter what driving mode you have it on, some sort of active handling is still active. You need to hold down the trac control button for 5 to 7 seconds to turn off everything. Do your burnout.
Since you have drag radials, you can probably race it like that but be careful, you might want to put it back to one of your driving modes after you do your burnout. Good luck...
I did hit the button in on the twice and both lights on dash said t/c off and the other one to the left was also light up. Not sure if holding it gives a different result. Would some sort of traction management still be on if both lights were on?
Leave it in Tour; press center button once to turn off TC; press and hold to turn off TC and AHC.
Try lightly pressure on the brake pedal while pressing the gas pedal. You only want enough brake pressure so the car don’t move. If you press full brake pedal the rear brakes are stopping the rear tires from spinning.
Bob
Bob
It’s very possible that was part of the problem. The burnout box was pretty dry and the brand new ET Street R tires didn’t help either. Next time out I’m sure I’ll figure it out. First time dragging an auto at the track. Last car was a manual and it was 16 years ago.
