Finished the build on the Z
Just got the car back from SSLSX Tuning in Concord, NC. I wanted a conservative street build.
We went with a
BTR Cam w/38% fuel lobe and accompanying hardware
Cordes Performance Heat Exchanger, Expansion Tank, and DOD delete valley cover
Kong Performance fully ported blower and snout
Katech 103mm TB
Holley intech CAI
Griptech 2.31 upper pulley
Brisk plugs
Kooks Longtubes/midpipe
MM Solutions catch can
It put down 698hp/702tq on only 10lbs of boost
Car drives like stock until all hell breaks loose making peak torque at 3200rpm
Will prob swap the lower pulley and do flex fuel later or swap the blower and turn it up...
Can't seem to load idle and dyno video, but they are on youtube on SonicZ06
We went with a
Katech 103mm TB
Holley intech CAI
Brisk plugs
ajrothm (04-16-2019)
Supporting Vendor
nice job!! thank you so much for using our products it really means a lot to us.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Sinistr (04-16-2019)
We went with a
Katech 103mm TB
Holley intech CAI
Brisk plugs
We went with a
Katech 103mm TB
Holley intech CAI
Brisk plugs
NICE power for such a simple combo....especially for no meth or e85.
Care to post the cam specs?
We are doing a similar build on mine as I type....curious how it will stack up.
No Prob
Dur @50 Int 225 Exh 240 lobe sep 116 Lift Int.635 Exh .624.
It sounds healthy at idle, but there is no surge driving around town.
Yours makes good power for just an upper pulley. No doubt its gonna pick up a bunch if you put a lower on it. I'm going with an 18% lower, stock upper, Meth and E85.... I'm hoping for 750 rwhp with stock heads....we'll see I guess...
Wow... I'm going to be running a very similar cam.... (223/239, .635/.635, 115 lsa). Other cams like this ive listened too sound very mild. I'm hoping mine sounds decent at idle. I know it will drive excellent though. Sub'd for your idle vids.
Just listened to your vids on youtube. It sounds great. A lot better then most with that small of a cam. I'd be quite happy if mine sounds like that.
Yes, Kong ported blower, 103TB, 2" kooks, 3" x. Basically the same build as yours only a lower pulley instead of an upper and using meth/E85. I am adding a low side fuel system to help with the E.
My car is A8..... Is yours A8 or M7
Mine baselined 560 rwhp with CAI only.
Mine is M7
Great build, congrats!
Pretty much identical build to mine, except mine has high flow cats, flex fuel and a dsx low side kit. Mine did 690/720 on 93, and 753/763 on e70. Mine also put down a 9.73@143 (on 93 unleaded) on its first pass after mods.
I have since broken the spiders, and waiting for rpm/waveloc diff to get finished.
Pretty much identical build to mine, except mine has high flow cats, flex fuel and a dsx low side kit. Mine did 690/720 on 93, and 753/763 on e70. Mine also put down a 9.73@143 on its first pass after mods.
but i had at time Borla catless X pipe , katech ptb and an afe intaker Sooo.... F you and that 612/620 as my best outta 3 runs was 560/580
Sounds like you def gotta Fast one lol , wven Fasssster now babay
Neil
The tuner freaked thought it had been tuned, but when he hooked up the computer it appeared to be untouched
My 16Z m7 made 661/724 on 91 octane. Kook LT high flow cats,2300 maggy, AFE, 5% lower pulley and x tank. Next is a MSD boost a pump and a 10% lower. I have a 15 but don’t want that much boost. My low and high side numbers have been raised as far as I can go. Hence the need for the boost a pump. My boost is 14lbs, AFR is 11.8 and timing at 16 degrees. Conservative street tune. Don’t want meth or E85
Supporting Vendor
Great Build and Incredible Z. Congrats and love it my friend.!
__________________
#1 Forged Wheel Master Distributor for Corvettes Worldwide since 2010
Call/Text 440-915-6166
Forgeline*Anrky*HRE*PUR*Brixton*Vorstein er*Akra*Brembo*IPE and Many More....
REVIEWS: http://forums.corvetteforum.com/whee...r-reviews.html
WEBSITE: www.cw4L.com
EMAIL: sales@cw4L.com
PHONE 440-915-6166 CALL OR TEXT ANYTIME!!!
Follow us on Instagram @custom_wheels_for_less
Sinistr (04-19-2019)
