Diff. fluid
Old 05-14-2019, 05:07 PM
MJC611
CF Senior Member
Default Diff. fluid
Thought I would change Trans. and Diff. fluid in '17 Z06 M7, The owners manual says: Rear Axle use Dexron LS Gear Oil, the next line says eLSD (Z51, Grand Sport, Z06) use Dexron V1 ATF, The dealer parts dept. says Dexron LS, what are you using?
MJC611 is offline
Old 05-14-2019, 06:07 PM
jcchevy
CF Senior Member
jcchevy's Avatar
I guess they’ve changed the owners manual? My 2016 says the following and that is what I used. Also found it to be about 1/2 qt low from the factory
jcchevy is offline
Old 05-14-2019, 06:53 PM
RonC7
CF Senior Member
RonC7's Avatar
LS gear oil with friction modifier is for the differential. The Dexron ATF is for the hydraulics that activate the clutches. It's the differential oil that you may want to change.
See this great thread on diff / manual trans service:
https://www.corvetteforum.com/forums...d-service.html
Ron
RonC7 is offline
Old 05-14-2019, 10:30 PM
killerv6
CF Senior Member
Default Diff fluid and trans fluid change
I used 3 quarts of GM Dexron LS for the differential and I used 4 quarts of red lines best ATF fluid for the M7 my car's a16z I want to change the diff fluid it was one quart low from the Factory only got 2 quarts out should have been three
killerv6 is offline
Old 05-15-2019, 12:16 AM
MJC611
CF Senior Member
Thanks for the input, will use Dexron LS and Redline D4 ATF
MJC611 is offline
Old 05-15-2019, 08:48 AM
snampro
he that rolleth a stone..
Support Corvetteforum!
snampro's Avatar
Yup, Dexron LS for the Diff and Redline D4 ATF for the M7 trans. Did both at the same time and was a noticeable difference. Quiet rear end and trans shifts better, not to mention how low the fluids levels were for the original fill...kinda sad, makes me wanna pick on the people assembling these things..
the eLSD is something you don't need to touch as often, so I'd leave it be for now, and that's from a guy that likes to mess with things.
snampro is offline
Old 05-16-2019, 05:11 AM
okaythen
CF Senior Member
For those that had the fluids low from factory, was the car ok if you don't track the car and it's just for street use? Or some damage could be done since it's low? I better check mine it's been 6000 miles and one drag strip trip.
How many miles or months do you guys change diff and transmission fluid?
okaythen is offline
Old 05-16-2019, 05:31 AM
Mr. Gizmo
CF Senior Member
Mr. Gizmo's Avatar
I have a 2017 m7 2lz. On the first 500 mile oil change I asked the dealer to check the levels in the trans/differential and they said it was full. I would take it to the dealer for an oil change and ask them to check the fluid levels in the trans/differential
Mr. Gizmo is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
