Alky meth kit with E50
Hey guys, does anyone have an Alky meth kit while running a flex fuel kit? I'm running E50 with my DSX flex fuel kit and I just installed my Kong 2.175 upper pulley. I'm still on my factory pumps and wondering if meth would help support my fueling needs? I don't know much about meth and I am a little concerned about the chance of fire. Has anyone else run a similar set up? If so, what are your thoughts and results. I'm also looking at a DSX aux fuel pump, but wondering if I could install a single nozzle Alky meth kit to give me just a little more fueling.
I run a Alky single nozzle meth kit with the flex fuel kit and run 50% E but I also have the DSX aux fuel pump. Don't think the stock low side and meth kit will support E-50. With my setup E50 was all my tuner said the DSX aux pump low side would support with a single nozzle meth setup without pushing the low side to the limit. I am going to a dual nozzle meth setup soon so I expect to be able to support more than 50% E then. I installed a 1.5 gallon rear cubby meth tank which I like a lot better than the meth in the WW tank.
Originally Posted by jstewart
I run a Alky single nozzle meth kit with the flex fuel kit and run 50% E but I also have the DSX aux fuel pump. Don't think the low side and meth kit will support E-50. With my setup E50 was all my tuner said the low side would support with a single nozzle meth setup without pushing the low side to the limit. I am going to a dual nozzle meth setup soon so I expect to be able to support more than 50% E then. I installed a 1.5 gallon rear cubby meth tank which I like a lot better than the meth in the WW tank.
Well, that's what I thought. I'm running E50 already on my stock pump. I'd just like the meth to give me a little extra insurance. My plan would not be to crank up the timing
IMO If you are doing an upper and a lower pulley with the 1.7 blower the meth is a must to help cool the intake charge. I believe this is the only way to keep the car consistent in warmer climates, just my 2 cents.
With my factory blower I had a twin nozzle set up and CPRs low side fuel pump and could run full E. I was 700rwhp with that set up. Highly recommend a bigger HX and expansion tank. It wont make you more power but it will help keep you from losing it when things get really hot at the track. Living in AZ at the time and the temps were over 100 for weeks on end, the cooling of meth was a great benefit. Now with the 2300, H/C, and supporting mods I can only get to about E50/meth before running out of fuel. With that set up I am pushing 870rwhp. There are pros and cons about where to put the meth tank. Most do the WW tank for convenience. I like the stealth look of the rear cubby install plus the ability to use wiper fluid at times is nice. I just used RainX on the windshield to help keep things from sticking during long drives. Another thing to consider is the ease of getting meth. Not every town has it. I am fortunate as the petroleum distributer here has it in the pump just like gas.
It helps, i was just expecting more.
I am making 730whp on the blower, 790whp with a 50 shot, 870whp with a 150 shot on a mustang Dyno. Car is straight E85+direct port meth and has a wxm low side as well. The nitrous does have it's own dedicated fuel cell though lol
Meth is good
Meth is good
GeorgeR_Zed06 (05-30-2019)
I’m getting ready to put the same pulley on as you. I’m currently running E50 but with NO METH. IAT2’s 100-110 doing back to back pulls. Running the factory low side at 15.5 volts thru the factory fuel controller the low side is running around 58psi at redline and not effecting the high side and injector millisecond are still in the low 5’s. I am going to put a JMS voltage booster on along with a Cordes heat exchanger when the 2.175 pulley goes on. I think if you are fine with E50 the LPE high side pump might get you by. I’m thinking another two volts and running 17.5 vs 15.5 should offset the 1-1.5 psi of boost increase. We will see. Going from stock voltage to 15.5 made up the difference and some on low side pressure going from 93 octane to E50. I’m going to see how the low side acts running the 2.175 and if it ends up holding I will replace the high side pump if it gives me problems.
current mods are
Halltech Ram Air
Cordes 5” intake
ported LT5 TB
Kong ported blower
2.38 LPE upper pulley
NX lid
160 stat
norcal cat delete
borla x pipe
BBE bi fusion exhaust
SMG flex fuel kit
Brisk Plugs
Granatelli Wires
Fasterproms thermal reduction plates
current mods are
Halltech Ram Air
Cordes 5” intake
ported LT5 TB
Kong ported blower
NX lid
160 stat
norcal cat delete
borla x pipe
SMG flex fuel kit
Brisk Plugs
Granatelli Wires
current mods are
Halltech Ram Air
Cordes 5” intake
ported LT5 TB
Kong ported blower
NX lid
160 stat
norcal cat delete
borla x pipe
SMG flex fuel kit
Brisk Plugs
Granatelli Wires
current mods are
Halltech Ram Air
Cordes 5” intake
ported LT5 TB
Kong ported blower
NX lid
160 stat
norcal cat delete
borla x pipe
SMG flex fuel kit
Brisk Plugs
Granatelli Wires
Your IAT2s are telling you nothing. You need to be logging Manifold air temp...(MAT)…. I guarantee you that your post blower intake temps are WAY higher then 110*….. Mine are 160* with dual M15/M10 nozzles...
I will have to check. The car was happy enough to see 21-22 degrees of timing consistently on 93 octane before going to E50. Now the car is seeing 23-24.5. Have yet to see the car get spark knock on pump or E50 since it’s been tuned with its mods.
I think high IATs are just the way its going to be with the little 1.7 blower bricks. Meth definitely helps, although I don't see a huge temp drop from off boost MATs, it does seem to stop the climbing. I'm only running a 18% lower.. I can't imagine how high the IATs are on a cars with a 18% and 2.31 upper...
Yeah I hear ya.... They are pretty knock resistant it seems on E85/meth. We have 28* in mine... Hopefully they don't skip the knock/KR stage and go straight to melt down. I guess we'll find out.
