LT4 supercharger intercooler bricks question
Has anyone ever seen a failure on these new bricks causing outbound flow to be severely depleted?
I've been trying to diagnose this issue for months and it looks like I've isolated it to the bricks. My heat exchanger pump does not cavitate. When I pull off my inlet hose to the supercharger and run it into my expansion tank with the car off, I have full pressure. However,.once all is reconnected, I have almost nothing coming back out into the expansion tank. I've pulled the bricks and used water and air pressure to see if any blockage was present but nothing changed.
I'm fairly confident that no significant amount of air is present in the system as flow is good all the way to the inlet of the supercharger.
Make sure that almost all of the air is out of the tank. I think they recommended a bubble the size of a quarter. The pump will cavitate if there is too much air in the tank if you drive aggressively.
I run my pump through hp tuners for upwards of 45 minutes and the pump does not ever shutdown
I've never measured the outbound flow on mine but until I got almost all of the air out of my tank I had reduced power off and on. It didn't throw any cel's but it still killed the power.
I've already purged the air with the help of a shop. When I pull the inlet hose, you can see and feel that the pump is pushing fluid at full pressure into the blower. But again almost nothing is coming out. I have replacement bricks coming in today, so hopefully that's the issue
I don't think the pump varies it's out put based on how you are driving it at least the way mine is set up it doesn't. Also, the OP said he had an expansion tank (assuming its a secondary) so at least in my experience that bubble in the lower reservoir isn't that big of a deal as long as the ports on the oem tank are both submerged. With numbers like that you definitely have something going on. Lately mine have been 98ish crusing and 120 under sustain boost with methanol and about 148ish sustained without methanol @ 88deg ambient. I'm using a secondary expansion tank, Varimax pump(always on), Cordes XH and the pre 2017 supercharger. I cant think of anything else it would be other than an obstruction in the coolant path within the supercharger itself. Hope you figure it out and please let us know what the cause was when you do!
As an update, I swapped the bricks and water manifold. As a result, I have coolant flow again out of the supercharger into the expansion tank. My manifold temps drops quicker now and sustained boost doesn't send me over 200.
I did all my tests in 90+ degree ambient temperature with half my expansion tank empty and air in the system. Will update again once I get the intercooler loop purged
Pretty much new and it came out of a take off supercharger from Callaway. Its a 18 or 19 and I had to get the whole blower. They sold it to me for 1700 with pretty much no miles on it. In fact the blower will be for sale soon lol.
Glad you got it figured out.
Once you install an aftermarket ice tank, the air-space on top of the factory reservoir means nothing. The majority of the fluid the pump is pulling in, is now coming directly out of the ice tank. This works best because the tank is directly on top of the pump and the extra weight pushes it through the impeller a lot better than when it pulled from the opposite end of the car.
As long as your pump is moving a full column of fluid, any air trapped in the system (post pump) will end up at the top of the ice tank. Every now and then, you should notice a small amount of pressure when you open the lid. Just make sure the fluid coming into the ice tank has a good flow.
