Magnuson 2650
interested to see where you all go on fueling for this then as thats my hangup. I dont want to put a big blower on and then not be able to make power due to not having enough fuel.
Supporting Vendor
Premium Supporting Vendor
We have two on order. One is for an E85 car so it will be a beast.
Also factor in $3500 for injectors since there is no room for PFI, and you'll certainly run out of stock injectors on E85, even with a boat load of meth, way before you run out of blower. FTL....
https://www.lingenfelter.com/product...l#.XQK0GfZFwuU
I have a low side fuel pump... I will also get their high side as well... And will be running e85.
Edelbrock has one of these in development with port fueling
Im going with
Guessing it wont fit under the stock hood if it will work with port fuel injection...
Thats where I am leaning as well. And their big bore HPFP. I really dont want to do a cam, but might have to to get the fuel lobe. I believe their package with the GT35 cam is the one that they ran to like 1400hp... so a cam with a fuel lobe is probably required to get there.
Yea i have a +32% fuel lobed cam.... =D so much fun!
#34
