CORDES PERFORMANCE-Thank you Maggie 2650 install
#41
Im going to be running full e85 and used the upgraded Lingenfelter injectors... (The stupid expensive ones).... and a low, and high side fuel pump.... along with a cam with +32% fuel lobe.... My trackhawk should be done in a week or two... and then the vette goes in to get it done!
#43
Supporting Vendor
#44
Supporting Vendor
#45
My 2015 Z06 made 728 STP corrected RWHP (700SAE) up from the stock 545 STP corrected RWHP with the Maggie TVS2650 on 91 octane only (no meth or octane booster)
Mods are:
Magnum DI TVS2650R (patent pending)
NW 102mm throttle body
GM Performance CAI
All else is stock (heads, cam, fuel system, exhaust, cats, etc)
#47
#50
2650 is amazing.
#51
#53
Wow, 728rwhp from a blower swap and pretty much nothing else is amazing. Any idea on the ballpark this kit may cost?
#55
Supporting Vendor
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
#57
From the above post:
Mods are:
GM Performance CAI
In the "Part 3: video he says its running on 91 pump only.
Mods are:
GM Performance CAI
#58
Supporting Vendor
I'm trying to see if he is expecting me to believe it took that timing on 91 at that power level.
#59
More questions regarding post #45:
- Did the 1740 and 2300 blowers also have the 102mm TB? I’m guessing not by the low 1740 dyno number that I’ve seen people hit with 87mm throttle bodies. Inlet restrictions are a big deal on PD blowers.
- If we’re trying to compare actual blower efficiency and ability to make power between the 3 blowers, why aren’t we testing the 3 blowers at the same boost level? If the short block and exhaust system are the same, then the restrictions are the same to making power. All 3 of these blowers can play in this 600-700 HP range, so it’d be nice to see apples-to-apples.
- By just adding a 2650 blower, why can we now spin the short block several hundred rpm more? Did valve springs get changed too with the 2650? We know the 2300 is capable of making more power than shown above for sure if pullied correctly, so why are we stopping it short? Doesn’t seem like a fair comparison IMO.
- Just my 2 cents...maybe I’m missing something... very possible. lol
