Loss of power on track
Posted this in performance driving section but thought may get more views here
Today 15mins into my second track session my car (2015 stock z07 m7)all of a sudden started to lose power. It was 88deg out and i thought the car was just hot and went into limp mode although there were no messages of that on the dash. I let the car cool down and went out for the 3rd session and car still had no power on first lap so i pitted and loaded it on the trailer and headed home. Just checked my data on Cosworth toolbox and said max oil 266 and max water 230. Seems kind of low for limp mode. Going to call dealer tomorrow. Just looking to see if anyone has had this issue. I’m booked for Watkins glen July 15 and 16 so i hope this is am easy fix. Definitely thinking i need to add auxiliary radiator.
yep.. also it's possible you have some IC pump cavitation..
Basil2000 (06-28-2019)
The following 2 users liked this post by Mr. Gizmo:
Basil2000 (06-28-2019),
TuneTimePerformance (06-29-2019)
How do you know if you have a bad catalytic converter? I was wondering if this would cause the car to act like this. Car is bone stock. Have been tracking car for 3 years. Dropping car to dealer on Monday but trying to educate myself before then. Thanks
It's not your cats....they don't go suddenly. I agree with the guys above. You have air in the intercooler. When the intercooler bricks get hot two things happen. 1st you get a much less dense charge, so you lose power. 2nd the car pulls timing to keep detonations down, and you lose power. Neither is limp mode, and does not set a code.
Z06
This would be my first thought as well.
Thanks guys. My local Chevy dealer has a corvette tech that does my track prep. He is going to take a look at it on Saturday. I will let you know what he finds. I appreciate all of the experiences.
ken
ken
Mine did the same thing, It didn't throw any codes but it was so weak it couldn't pull a fat baby off a tricycle. I re-bled the ic and got most of the air out of the tank and never had it happen again. I thought at the time it was a converter but they were fine. You can't hurt anything by getting as much air as possible out of the intercooler tank and all you've got tied up is your labor.
23/C8Z (06-29-2019)
Received 8,928 Likes
Check the ECM to see if there are any codes. You may not have a CEL but there may be some codes like P0300. If you have that code there should be a history file that will tell you how many times a misfire occurred and on maybe which cylinder misfired. For 88 degrees your coolant and oil temps aren't that bad. I have the aux radiator and saw a max coolant temp of 221 and a max oil temp of 261 on Monday afternoon. I wasn't pushing as hard as I normally do as I had a student with me and I was showing him the line I use. On Tuesday afternoon I had another instructor with me and was pushing harder for more laps and saw a max coolant temp of 217 and max oil temp of 262. My lap time was 6 seconds faster than the previous run I mentioned.
Bill
I was still able to drive fast but just couldn’t put the power down to pass or pull out of a corner. The car was almost sputtering when first getting on the gas. Someone I know was behind me and said car sounded bad like it was miss fireing. Car starts up and sounds good but when I rev it, it sounds bad until rpms come back down.
Bill
Agree with Bill on that one.
Doubtful cavitation or cat failure.
Log the car and post it up here if it keeps happening after the visit to the shop. I hope it does work for you though good luck.
