Low voltage?
Just turned 30K miles.
The battery was replaced with a GM battery in April this spring. I had 2 choices and I bought the better more expensive one with a longer warranty.
Went out for a ride yesterday and the system voltage dropped to 12.5 volts and flickered to 12.4. (Mostly expressway driving).
I decided to turn around and head home. As we got closer to home and in more stop and go traffic the voltage came back to 12.8v.
The overall ride was about 40 miles with 35. miles at 12.4v/12.5v and the last 5 miles at 12.8v.
I have a Range AFM disabler plugged in and a GM (Corvette brand) battery tender plugged in.
In the 8 years I've owned the vehicle it has always operated between 12.8v and 13.7v with an occasional brief drop to 12.7v or a bump to 14.0v but never 12.4 and 12.5.
Should I be concerned?
Any suggestions on what I might look at?
It started around 14.7 volts then after a while it dropped down to 12.8 volts.
The voltage behaved as it normally does.
I will definitely check the small black wire and report back on its condition.
Thanks all.
After a while it may drop down to 12.8 +/- 1 occasionally 12.6.
The small black wire on the battery looks intact.
For now... I'm gonna keep an eye on it.
Thanks all.
I never understood gm putting voltmeter on dash until my battery died recently. It's very sudden.
