C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
ZR1: LT5 cover leaked!
Old 10-27-2017, 07:39 PM
  #41
383vett
CF Senior Member
383vett's Avatar
Originally Posted by skank View Post
Hope they have a beautiful machined alloy top (ala C6 ZR1) showing a designed ribbing (ala Bugatti Chiron).
Doubt it. The engine cover for a Chiron cost more than the ZR1 will.
383vett is offline
Old 10-27-2017, 07:51 PM
  #42
davepl
CF Senior Member
davepl's Avatar
Received 1,434 Likes on 955 Posts
People keep mentioning Mercury Marine, but there's little chance GM is partnering with them again. Back in the (old) LT-5 days GM did not have extensive experience with aluminum engines, or that's what I understood. So they partnered with MM, who did.
GM certainly needs no help with aluminum engines these days!
Also, a DOHC motor is no grand leap. It might be for the Corvette, but GM has had "high feature" DOHC V6s for a long time. Just add 2 cylinders, no need to call in outside help.
davepl is offline
Old 10-27-2017, 08:46 PM
  #43
MikeyTX
CF Senior Member
Support Corvetteforum!
MikeyTX's Avatar
Location: Slowly driving my way around the United States
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17
NCM Lifetime Member
Originally Posted by Quinten33 View Post
It's a Gallo 24.
Ernest or Julio ..........
MikeyTX is offline
Old 10-28-2017, 01:25 AM
  #44
sunsalem
CF Senior Member
sunsalem's Avatar
Received 1,534 Likes on 1,141 Posts
Like you, I doubt GM needs help building engines.
AFAIK, Ford didn't need outside help for their GT350 engine.
sunsalem is offline
Old 10-30-2017, 01:25 PM
  #45
village idiot
CF Senior Member
village idiot's Avatar
Originally Posted by lakemg View Post
If the LT5 is truly an OHC setup, it would have 4 valves per cylinder. The 4 valves take up a lot of realstate in the combustion chamber leaving the center of the head the ideal spot for it to be positioned, hence the need for it to go through the valve cover.
Yes, but many cars that are DOHC have the plugs in the side (at least that's what I recall from a few cars).
village idiot is offline
Old 10-30-2017, 01:42 PM
  #46
OnPoint
CF Senior Member
OnPoint's Avatar
Received 2,057 Likes on 1,149 Posts
DOHC heads place the sparkplug in the middle of the chamber and between the valve banks.
Here's a pic of the underside of a DOHC head, you can clearly see the hole for the spark plug in the middle of the valve banks:
Here's a pic of a DOHC head from above - also easy to see the spark plug arrangement between the valve banks running down the middle of the head.
OnPoint is offline
Old 10-30-2017, 02:17 PM
  #47
village idiot
CF Senior Member
I know that's traditional, but I could have sworn my old beater had the plugs on the side. Maybe it wasn't 4 valves/cylinder.
Old 10-30-2017, 02:32 PM
  #48
davepl
CF Senior Member
davepl's Avatar
I can't -think- of ever seeing an engine in that configuration. If you think about it, a 2-valve engine has room in the chamber on the side, but a 4-valve ONLY has room dead center, really.
davepl is offline
Old 10-30-2017, 02:36 PM
  #49
village idiot
CF Senior Member
No it makes sense. And I know center is where it is traditionally (I've done many plugs on my bikes), but I could have sworn my old Subaru beater had them on the sides. Hence why I said "have to be"
Old 10-30-2017, 02:39 PM
  #50
\Boost Monkey/
CF Senior Member
\Boost Monkey/'s Avatar
I don't think I've ever seen a DOHC with plugs in the side, not sure one even exists.
\Boost Monkey/ is offline
Old 10-30-2017, 02:44 PM
  #51
mschuyler
CF Senior Member
mschuyler's Avatar
Received 2,665 Likes on 1,186 Posts
If I'm reading between the lines correctly, there is some speculation that this valve cover has been photoshopped. This is what Furman had to say on Sunday.
~ZR1...Mid Engine...Spy pics, I don't mind questions about possibilities. What gives me extra work and that spins my wheels are photoshopped pics and stating that it's real and coming to a dealer near you. How do you tell the difference? Well when it's Font used from the 4th Generation and its stated that it is for the 7th Gen ZR1...well then yes it's not real and someone was either duped into thinking it's real or is trying to dupe all of us...either way it causes more questions then they are worth.
Is he talking about this cover?
mschuyler is offline
  #52
\Boost Monkey/
CF Senior Member
Most Subi's have DOHC Boxer engines which are flat 4's or 6's. The plugs are technically on the sides, but that's because the piston chambers are flat and hence the plugs still go through the valves for each chamber.
Old 10-30-2017, 03:23 PM
  #53
village idiot
CF Senior Member
That might explain it too, but I honestly don't remember. Other than my college beater and bikes, I don't think I've owned or worked on a 4v/cyl vehicle. I just remember the plugs being a huge pain in the dick and on the sides of the engine.
Old 10-30-2017, 04:53 PM
  #54
sunsalem
CF Senior Member
sunsalem's Avatar
[/SIZE][/FONT]
I hope not...otherwise, this thread is all for naught.
sunsalem is offline
Old 10-30-2017, 05:11 PM
  #55
dmaxx3500
CF Senior Member
dmaxx3500's Avatar
guys don't discount mercury marine as an eng builder,they can run small runs,,GM isn't set-up to run 500-1,000 engines,,and the DOHC heads merc is building are designed to fit ''stock 6.2 LS engines'',i also was told they were cast by edelbrock ,also because of the small run ,and whos to say its NA or supercharged or even turbo'd
merc's big block 9 liter eng makes from 900-1450hp on pump gas,NA and turbo'd,,and there 7 liter dohc makes 750hp NA,id bet there is a supercharged version making 900+hp,and a twin-turbo package too
the 7 liter eng fits where a reg LS eng fits,[ I cant say how I know -but ive seen one in a vehicle,and 2 pairs in boats],,and if anybodys going to SEMA this week,look around as there will be 2 or more of these engines there
dmaxx3500 is offline
Old 10-30-2017, 05:25 PM
  #56
2K14C7
CF Senior Member
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
“We just revealed our latest automotive aftermarket crate engine, the SB4 7.0. The 32-Valve DOHC V-8 was designed, developed and manufactured in-house.
The 32-valve cylinder head and DOHC valve train design is a decendant from our 9.0 QC4 engine platform.
The naturally aspirated, 7.0 Liter engine features Mercury Racing’s exclusive aluminum four valve cylinder heads and dual overhead camshaft valve train integrated with a LS cylinder block packed with Mercury Racing designed and specified hardware.
This proven valve train, which greatly enhances engine durability over a standard two-valve design, enables the engine to produce a staggering 775 horsepower at 7500 RPM on 91 octane pump fuel!”
2K14C7 is offline
Old 10-30-2017, 06:51 PM
  #57
GTB/ZR-1
CF Senior Member
GTB/ZR-1's Avatar
Hmmmmm. Maybe they hot-rodded up those old C4 LT-5 ZR-1 engines they had laying around, gathering dust in the back warehouse... lol
GTB/ZR-1 is offline
Old 10-30-2017, 08:45 PM
  #58
MikeyTX
CF Senior Member
MikeyTX's Avatar
NCM Lifetime Member
Now that, would get me off the dime. Gee, would that be a gas at cars and coffee.
MikeyTX is offline
Old 11-03-2017, 08:01 AM
  #59
LT1 Z51
Corvette Enthusiast
LT1 Z51's Avatar
Originally Posted by [email protected] View Post
All I can say gang, without any more detail, THAT IS FROM THE CAR...where it is, etc etc etc I cannot answer to protect the sender.
I was told its a supercharger car,(which most of have thought) but we will all wait for the official GM announcement , specs and so forth!
It's a supercharger, should be good for 700+ Horsepower.
LT1 Z51 is offline
Quick Reply: ZR1: LT5 cover leaked!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
