Car and Driver ZR1 Cover....
#201
Sorry, I was trying to make a joke there.
OK, got ya.
ME stands for mid engine. Everyone is saying the ME is coming out next year at will be around 150k...I don't think that unicorn will be 150k when the FE is that much
#202
I think the ZR1 will likely just barely crack the 7min mark...6:59xx at the ring...
For those expecting more from it...the question is, what were you expecting? The C4 ZR1 looked just like the regular C4, so did the C6 ZR1....other than a few fancy parts the avg person would have no idea. So why should the C7 ZR1 be any different?
It has always been more of a balanced car than a track car...this time they made the track variant to correct the perceived wrongs of the C7Z (i.e. track issues).
Lastly...I have a hard time believing the GT2 RS time...I can't wait for the ZR1 and GT2RS head to head at MRLS...and I have a feeling the ZR1 will be on it's bumper maybe even ahead of it...yet at the Ring the GT2RS ring time was blisteringly fast...typical Porsche 'massaging.'
I like the new ZR1...still the performance value of the century. Mid 10's at the strip (maybe even 9.9 on a tire), super fast on the track, comfortable, reasonable gas mileage and all for under $140k (likely). What else even comes close?
skank (11-11-2017)
#203
The GT2 RS has Absolutely all its Electronic ducks in a row - love it! ;)
If a Vette with far fewer of everything gets in the mix!?Again!
#205
skank (11-11-2017)
#206
I have heard Tadge talk about this on Autoline. When they started the C7 they did some N/A engine development, but they could not reach the horsepower goals and still meet emission and gas mileage requirements.
If you look at most other sport cars, the trend is to smaller displacement turbocharged engines.
#208
Received 1,817 Likes
#209
#210
#211
A DOHC can be N/A or turbocharged or supercharged. I know some people on this forum like supercharging, but it adds a lots of weight and its parasitic load hurts gas mileage. So then the Corvette engines where forced into adding cylinder deactivation which added 80 to 90 pounds. That's part of the reason why the C7 Z06 and ZR1 are overweight. Turbocharging is a much better way to go and that is trend your seeing in most cars and trucks.
VetterFlyer (11-11-2017)
#213
A couple of things going on with that. The pushrod engine is a much more compact design than an overhead cam. Have you seen the Ford overhead cam V8's side by side with the LS or LT GM? The Ford is huge in comparison, probably wouldn't fit under the Corvette hood.
Overhead cams have their main advantage on higher-rpm engines. On an engine with a displacement as large as the LT4, one doesn't want to spin them so fast that piston speed (and the distance the pistons and rings travel per minute) goes above a certain level, because the wear gets really high for an engine with a warranty. It's fine though for an engine which will be torn down and refreshed periodically. All-out race engines only need to survive the distance of one race. OEM engines need to work to a different set of standards.
#214
Porsche 911 turbo s 580 hp 518 tq weighs 3527
Corvette z06 650 hp 650 tq weights 3524
How is the corvette overweight?
I believe the ZR1 is supposed to have 750 hp, 680 tq weighing an extra 140 lbs...
So 211 mph top speed ZR1 could weigh in at 3664 lbs..
That gigantic wing probably weighs 70 lbs...(kidding) ...
#215
The problem with big displacement motors is the emissions during cold start up. Until the unit heats up and the cats fire off, most of the harmful pollutants are happening the first 2 or 3 minutes. Once any modern engine heats up, they put out very little in the form of harmful emissions.
Amazingly the naturally aspirated V10 Viper motor is certified as a low emissions motor but it will not pass future cold start up emissions. The future will be very small V8's and V6's that are force injected to get the power when needed.
#216
While I agree that turbocharging can be more efficient, I haven't seen any evidence that it provides some kind of across-the-board weight reduction. I'm willing to learn though, if you can provide the evidence.
#217
