C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Do you think the ZR1 wing will retrofit?
Old 05-20-2019, 11:01 AM
  #181
Wikd Vet
Junior Member
Originally Posted by ssmith512 View Post
Same T30 security bit as the pedestal bolts.
Awedome, ty...
Wikd Vet is offline
Old 05-25-2019, 10:25 PM
  #182
mdk
CF Senior Member
mdk's Avatar
mine did not come with the bolts to attach wing to brackets.
mdk is offline
Old 05-25-2019, 11:22 PM
  #183
Wikd Vet
Junior Member
Call Kent from Weapon X. He'll take care of you. He got their supplier to overnight me a set. They are kinda specialized bolts. I think it costed like $145.00 for the bolts and over night shipping. Take a look at the circular and square holes contained in the brackets attached to the bottom of the wing. Mine did not line up and the nuts and bolts could not be joined together. I had to modify the brackets alot to get the nuts and bolts to be able to be lined up and screwed together.
Wikd Vet is offline
mdk (05-26-2019)
Old 05-27-2019, 04:10 PM
  #184
Wikd Vet
Junior Member
Hmmmmm,...I dont know if I am happy for you or hate you! LOL!
Seriously, awesome news! I hope those of us waiting for the ZTX wings will get our shipping notification soon!!!
And as I stated before, I respectfully DEMAND pics upon receipt!!!
Here ya go bud.....
Wikd Vet is offline
The following 2 users liked this post by Wikd Vet:
Hirohawa (05-27-2019), ssmith512 (05-27-2019)
Old 05-27-2019, 04:15 PM
  #185
ssmith512
CF Senior Member
SWEET!!!
Big **** Club Rules!!!
Carbon fiber body spoiler!! I like!! Where did you source that beauty?
Car looks WICKED!!
ssmith512 is offline
Old 06-01-2019, 04:35 PM
  #186
mdk
CF Senior Member
mdk's Avatar
Test Fit
This has been a great project, almost done.
thanks everyone for posting all the photos and information.
mdk is offline
Hirohawa (06-01-2019)
Old 06-01-2019, 08:43 PM
  #187
Mu$cle
CF Senior Member
Mu$cle's Avatar
MDK,
Your pictures are very helpful. Can you provide additional detail (maybe a close-up picture) on the upper bracket mounting bolts - those on each side of "OUT"? Did all the mounting hardware come with the wing mounting kit or did you have to figure out what to use where? Thanks.
Mu$cle is offline
Old 06-02-2019, 08:23 AM
  #188
ssmith512
CF Senior Member
Looking good mdk!!!!
Heres is what I did......drill the rivet out with a 1/4" drill bit. Went to Ace harwdware and got some 6mm bolts, 6mm washers, 6mm spring lock washers, 6mm locknuts and 6mm nuts.
See pic on how i used nuts and washers along the length of the bolt between the bulkhead and bracket. Order from inside the car is: bolt head, washer, bulkhead, washer, spring lock washer, nut--------nut, spring lock washer, washer, wing bracket, washer, lock nut. I cant remember the length of bolt I got - maybe 80mm long??
Install the wing bracket, insert the bolts and nuts and washers in order. Tighten the outer most locknut until it just touches the washer (outboard of the bracket facing the rear of the car). Then you can tighten the two nuts between the bracket and bulkhead down good and tight.
The following 2 users liked this post by ssmith512:
Hirohawa (06-02-2019), mdk (06-02-2019)
Old 06-02-2019, 08:26 AM
  #189
Mu$cle
CF Senior Member
Mu$cle's Avatar
Very helpful. Thanks. Now all I need is the wing.
Mu$cle is offline
Old 06-02-2019, 02:55 PM
  #190
ssmith512
CF Senior Member
Glad to help! Hopefully soon my friend!!
Also, if anyone cares, the ZR1 car cover (GM part #84053409) fits the ZTXL wing. It is a tiny bit tight around the wing end plates, but fits OK.....
Old 06-13-2019, 06:24 AM
  #191
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 2,320 Likes on 953 Posts
Originally Posted by Wikd Vet View Post
Anyone know what type and size of bit we need for tightening these 8 bolts that attach the wing support brackets to the pedestals?
Does anyone know the part number for those bolts. A couple of mine are a bit buggered and I'd rather replace them before they get completely stripped.
Also, I had a chance to track test my GS with the ZR1 wing and stage 3 splitter. The aero balance is actually very good.
Poor-sha is offline
Hirohawa (06-13-2019)
Old Yesterday, 06:37 PM
  #192
KGrant
CF Senior Member
KGrant's Avatar
How is the flex on the wing! Another forum member bought wing from another vendor and it has been a disaster as wing was damaged 3 times in the mail and then the 4th wing as too much flex and started to crack as they only used one layer of Carbon Fiber so it wasn't stiff enough so he's starting over.
KGrant is offline
Old Yesterday, 07:43 PM
  #193
ssmith512
CF Senior Member
Wing is rigid as heck. I wouldnt hesitate a bit to use it on a road course at high speed. I believe Ben has run it on his ZR1 to 150ish??
Wing is the real deal, not some fluffy appearance only piece.
KGrant (Yesterday)
Old Yesterday, 07:52 PM
  #194
KGrant
CF Senior Member
KGrant's Avatar
I now see that "TensionC7" is a contributor to this thread and felt bad for him trying to get his wing.... glad to know WeaponX Wing is stiff, the Real Deal and functional.
Wing is rigid as heck. I wouldn't hesitate a bit to use it on a road course at high speed. I believe Ben has run it on his ZR1 to 150ish??
KGrant is offline
Old Yesterday, 10:45 PM
  #195
Poor-sha
Track Rat
Poor-sha's Avatar
I'm using an OEM wing and it's fine. I had to have mine repaired after the accident but they did a phenomenal job.
Poor-sha is offline
Quick Reply: Do you think the ZR1 wing will retrofit?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
