Carbon Flash - New Wheel Option for ZR1 Only
I'm sick of round wheels. They've been doing this since the cave man. Come on GM.
z edge (02-25-2018)
Not trying to pick a fight, but I don't see how those wheels could possibly look any better in person. They are a completely underwhelming design, almost identical to what was on a mid-80s Testarossa. The standard Z06 and Grand Sport wheels are light years better looking IMHO.
They are awful, look at the finish around the lug holes seems they have dirt and a hair in the paint. Those are the worst looking Corvette wheels ever put on a modern Corvette!
https://jalopnik.com/the-shelby-gt35...use-1717009943
The 2016 Ford Mustang GT350R is the first proper production car to come standard with carbon fiber wheels, and the front pair uses the same ceramic plasma arc spray-on heat protection what NASA put on the original Space Shuttle’s main fuel pump turbine blades. That should do it!
Carbon fiber wheels are something else. They work brilliantly on the world’s most powerful electric bike (which I tried out and found amazing), and of course Christian von Koenigsegg came up with a way to make them weigh just 13 pounds each.
K-Segg’s wheels are hollow and hold up pretty well at crazy speeds, but a set of Aircores will set you back by more than what an average family sedan costs. To be exact, 60,000 Euros without taxes but with the Michelins included.
While BMW is toying with the idea of affordable carbon fiber wheels, Ford acted faster by teaming up with the experts at Carbon Revolution to create something that can be mass produced at an affordable price, but also take the abuse on track.
To turn them into OEM products, the wheels had deal sufficiently with curb strikes, UV and chemical exposure and extreme heat. Ford claims despite what people think, hitting a curb with these babies won’t be an issue:
One of the most severe tests for wheels in the Ford development process involves striking a curb at speed – a test that, without proper design, can cause serious wheel and tire damage. Because of the light weight, advanced construction methods and resins in the wheels, along with the highly-developed MagneRide dampers, the suspension was able to react so fast that the driver wasn’t sure the test had been carried out correctly and ran it twice to be sure. The suspension response was fast enough to greatly diminished the severity of the impact – that’s the power of minimizing unsprung weight.
The Shelby GT350R’s brakes also create rotor temperatures in excess of 1,650 degrees Fahrenheit (900 degrees Celsius), but Carbon Revolution’s thermal barrier coating system takes care of that as well using a multistage, multimaterial coating formulation. They use a plasma arc gun to liquefy a ceramic material, and then the wheels are coated at critical points around the inner wheel “barrel” and on the back of the spokes.
The result is a thin, “nearly diamond-hard coating” that allows continuous track use “by even the most aggressive drivers.”
That’s not the end of it though, because they also had to come up with new precesses to create a smooth finish despite the additional UV and chemical protection. High-gloss black is what you get.
The complete build process goes like this:
Manufacturing carbon fiber wheels begins with the creation of the preformed internal carbon structure, composed of precisely manufactured carbon strands arrayed into woven fabrics. The elements are then placed into a mold using state of the art manufacturing techniques.
An RFID chip with a unique tracking number is embedded in this structure, and each wheel is individually entered into a quality assurance system. Once this structure is assembled, it’s infused with resin and cured at high temperatures.
This process results in a one-piece wheel that ensures maximum strength – eliminating the need to bond or glue the wheel’s spokes and barrel components together.
As the wheel cures, 61 individual checks and more than 246,000 data points are logged before it’s released from the machine. To guarantee quality parts, the cured wheels are analyzed using a 3D computerized tomography (CT) imaging process in which more than 18,000 X-ray images are taken. If the wheel passes inspection, it undergoes machining for the valve stem and mounting hardware holes before it gets painted, coated, assembled, dimensionally checked and shipped to Flat Rock Assembly Plant for installation on a new Shelby GT350R Mustang.
The resulting wheels weigh 18 pounds instead of 33 like an alloy. That’s a pretty significant reduction in unsprung weight and rotational inertia.
Ford says they lost 60 pounds while making the wheels stiffer as well, so they believe “this is a game changer for the industry.” Well, it sure looks like it!
I can't stand split-spoke wheel designs. Looks tacky and a pain in the rear to clean.
IMHO, it's really hard to beat that classic Cragar look. Of course, I've never cared about wheels and don't understand the obsession with them at all. I just want some strong, lightweight wheels that are easy to clean, and I'm good.
I don't know what you're getting at here, I said I wonder if they're not using them because they want to keep the costs down.
Could have saved all that no one is arguing that carbon fiber is not lighter and better for performance.
1) Why is "why are they not using a CF wheel" a silly question?
2) Who the f'k is arguing?
3) You're making more out of this than any sane person should.
NortonCO (10-17-2019)
1. To finish you left out the "because they want to keep the costs down" it was a good oxymoron all in one sentence ! That was my only point!
RIF so is comprehension man.
Does anyone have a picture of the Satin Graphite painted rims?
Received 9,512 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
c5c6c7 (02-24-2018)
The wheels will have to be kept super-clean in order for anyone to notice the carbon flash, otherwise brake dust will completely hide it.
Has anyone seen the polished Aluminum?
#34
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Any of you voicing your dislike have seen them in person or better yet are buying a ZR1 ? Don't like the wheels, don't buy it or change them after. They look much better in person.
I'd prefer to see more carbon flash trim options vs all the carbon fiber.
The following 3 users liked this post by DebRedZR1:
#36
CC's don't develop brake dust unless you are intentionally trying to kill your pads. Literally 300 miles and they will pass a white glove test. A nice perk.
#37
#38
#39
#40
