Build quality issues already
Not sure if his is an isolated issue (if it is in fact an actual issue) but I can confirm my centerlines are as close to perfect as I can tell. I am VERY sensitive to things like this and have yet to find any major issues with my ZR1. Pis below of my engine cover and hood vent.
Where the stanchion mounts for the ZTK wing meet the body color "little spoiler" attached to the rear deck, one of them is higher than the other. Neither are flush, but one has a mm or so more gap (super **** I know, but I did notice upon first inspection). Not a huge deal but I did ask my R8C delivery representative and he got the PDI tech over to look at it. He said "they all go together a little different" and that GM had confirmed small gaps/irregularities where the stanchions meet the body are normal. Pics below of stanchion gaps.
Bottom line: There is ZERO sloppiness on this car
Driver Side Stanchion Mount
Passenger Side Stanchion Mount (More Gap)
DebRedZR1 (05-02-2018)
I was at the Bash in BG today, during the outside walk around of the ZR1 Tadge made specific references to the carbon fiber engine cover, splitter etc. He said every piece had to be perfect the way the weave goes together and the lines had to be perfect for this car. He was absolutely adamant about it, every ZR1 there today looked very very good.
So no I don't buy this either.
XpatVetteLover (04-28-2018)
I was at the Bash in BG today, during the outside walk around of the ZR1 Tadge made specific references to the carbon fiber engine cover, splitter etc. He said every piece had to be perfect the way the weave goes together and the lines had to be perfect for this car. He was absolutely adamant about it, every ZR1 there today looked very very good. So no I don't buy this either.
did you see the video? It's not like he's telling you and you have to take his word for it.
and not for nothing but it Tadge believes what he said like any good corporate guy what's he gonna say? We know everyone can't be perfect so if a few are not right we'll fix it? No that's what the dealer support network is for. Is it a big deal? Not even close.
On regards to his front splitter being damaged or failing as he put it, I bet that happened coming off the dyno.
It's been happening more & more lately. If people don't slow their roll shilling for these dillweeds, IB might stop allowing Youtube links.
The following 3 users liked this post by redzone:
Would be his 4th or 5th corvette he crashed and blew the guy off
Hopefully these pcm stay locked for good!!!!!
Cars are perfect right from GM!!!
Its not click bait. Video starts silly but a few min in he talks about how the hood line is not lined up with the carbon fiber covers. Thats extremely poor in my opinion and is very visible. I wouldnt take delivery of a car if it looked like that.
again the video is not a joke although it starts like one
I just read all the comments. Can you all please fast forward the video to the part where he shows the concavity of the carbon fiber front engine cover and the line of the hood?
Good Job! ;)
You have no idea if he hasn't pulled the carbon fiber canopy off and reset it wrong on the engine itself. The guy is obviously a meathead and has a propensity of messing around and changing stuff up. His juvenile burnouts says it all. Then he brags about it. Watching the Bash video's of Kai Spande showing the new factory upgrades you can clearly see in the video where a factory worker is installing the carbon fiber canopy using setting gauges for proper alignment. There must be a certain amount of position adjustment allowed in the design of the canopy to readjust it's position. That is typical of all overlays like that. As far as his complaining about the carbon fiber alignment as it curves down over the biguet curve of the canopy, it will never continue the oversquare alignment points that takes place on a planar surface.
The issue with the center lines of the carbon fiber being off is clearly visible on this video as well. Take a look at minute mark of 1:10 or so. You can see the first and the second carbon fiber pieces of the hood/engine dont line up and its very visible:
The Z (05-05-2018)
#33
Scraping the splitter.
https://youtu.be/0hBtFwt4OGI
This seems to be an incredibly petty thing to worry about, but I'm somehow not entirely surprised.
S.
The following 2 users liked this post by Snorman:
Aerovette (05-02-2018),
NewYuriCity (05-02-2018)
#34
In another thread someone posted a link to the install instructions for the performance air intake. A part of the install is to remove the SC cover and they specifically show you where to mark the current location with tape in three places so it goes back on in the correct spot. That tells me that the SC cover has some adjustment in placement and if he really cared he could just fix it himself. I'm with the others that it is entirely possible that he removed the SC cover himself and didn't quite get it back on in the correct spot.
#35
And you can also see the engine moving on the mounts as the car is under heavy throttle. Not sure if you realize it, but that canopy is a moving part. As the engine moves, and the engine mounts and chassis settle, I'm going to guess it'll shift very slightly.
S.
S.
#36
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
#37
#38
#39
