2019 ZR1 Stock Tire Record Run at Richmond Dragway
The following 6 users liked this post by wfarmer.z:
furiousox (05-01-2018),
JMB (05-01-2018),
SpeedyD (05-01-2018),
tail_lights (05-01-2018),
z edge (05-01-2018),
and 1 others liked this post.
According to these links (source is autobild), Porsche GT2RS does the 1/4 mile in 10.3s @ 139 mph. Considering these two cars are close to each other in terms of power to weight and considering Porsche has just as much drag with its giant wing, why is there a massive trap speed difference?
Porsche weighs 3309 lbs and makes 700 hp (and a lot less torque than vette). That is equivalent of 3580 lbs and 757 hp, a mere 2 hp more than ZR1. I'm not buying it to be honest. There is no way there can be 6 mph of trap speed difference but both clocking 10.2-10.3s.
http://fastestlaps.com/models/porsche-911-gt2-rs-991
https://www.flickr.com/photos/dedeth...57695538380775
https://www.flickr.com/photos/dedeth...7695538380775/
Platinum Supporting Vendor
Drag racing is not as easy as it seems and there is a lot that can play into it.
I just read up on the Porsche and a turbo car will do that. It is really hauling at the end of the track but it can't make up the distance that the Z has already covered. So the times are really close but the trap speed goes to the Porsche, it is running the Vette down and in a 1/2 mile race it would have beat it.
Has anyone seen a real dragstrip time for the GT2RS? Not sure how Autobild test the 1/4 mile but they may be giving an actual speed not a trap speed. The trap speed is an average speed over a short distance and can be less than the actual speed.
Great Run Farmer!
Unhandled: The GT2RS dyno'd 680 to the rear. That, combined with almost 300 lbs lighter... it's going to mph like nobody's business.
Best Regards,
Dave
Best Regards,
Dave
Farmer getting it done! So the lowest time for any ZR1 is 10.1 on drags and 10.3 stock? Can’t go wrong w that!
Nice run, what makes it more impressive is that it appears to be an open track day and not a private rental where you can get optimal track prep to yourself. Which stock tires did this have the super sports or cup 2?
Wfarmer, any reason why you don’t use PDR?
Awesome run!
Wfarmer, have to ask. You have damn near identical times with the Z06 in both stock and drag radial form: https://www.corvetteforum.com/forums...-fast-list.htm What are your thoughts now between the two?
While his current E.T.s are only about .1 second better than his best in his Z06, you really need to take a look at the 60' times and the DA for his Z06 runs. The same air and 60' times would improve his ZR1 times by .2 to .3 second. I think the best ZR1 times will end up being ~.4 sec quicker than the best Z06 times.
The Consigliere
Received 5,432 Likes
Farmer reported at the time, negative DA and very good track prep, and a slightly better 60', at MIR for his bone stock run in his Z06.
And it's still pretty early. I bet we see higher mph - particularly when run in similar negative DA and conditions.
Good times!
What surprises me about the ZR1 is them only picking up 25-26 mph on the back 1/2 of the 1/4 mile. I would expect closer to 30mph, I wounder if that's drag or something in the tune. Would be interesting to see a log and see if AIT's or something is pulling timing past 110 mph or something.
Ok, but I am looking at the mph specifically. Plus the ZR1 had +500 DA. I don't know for sure but I would imagine the Z06 run has worse. I expected a bigger difference between the two than what we are currently seeing. Kind of like between the C6Z06 and the C6ZR1. There was a substantial mph difference between the two. Here the Z06 had a higher mph which I would never have expected unless it was a bad run for the ZR1.
RoketRdr (05-01-2018)
