C7 ZR1 Fast List
IMHO the fast list should be members here with a Corvette Forum username. Not a member here, their times should not count. It's their job to fill in the blanks of the fast time format, not anybody else.
To the OP, thanks for taking what will end up being many hours of work for the members of this site. Even though I'm currently living on the dark side of the Hellcats, I still enjoy this site and appreciate a well run web site that's full of great data that's easy to find almost anything Vette related.
DebRedZR1 (05-14-2018)
One more thing that may help you head off possible problems before they get started. Back during the C6 days, one member tuned his car, then detuned it which led to some aggravation for the person(s) keeping up with the fast list, because some thought it was still showroom stock, while others that is wasn't truly showroom stock. On the C7 section that wouldn't have flown.
Former Vendor
2019 ZR1, 100% Stock
A8
ZTK (full aero installed)
Sport Cup 2 Tires
Best run:
60' 1.64
1/8th 6.96 103.34mph
1/4 mile: 10.75 128.29mph
DA +1100, Cecil County
A8
Sport Cup 2 Tires
Best run:
60' 1.64
Ahhhh, there we are! Thanks HPA! Great Run! What are your thoughts on taking the Z down the strip?
Scraping the splitter.
A bit of advice from when I managed this list for the Z06's.
Suggest adding a "Post #" column, and I'd also suggest hyperlinking the links to the posts. Then if this document is shared, people can simply click on the link to the post.
Enjoy!
S.
Enjoy!
S.
will add a post # column. I wanted to hyperlink but I’m just print screening the list. I’m not sure how to do that? Can you assist? Suggestions on how to do so?
Ran my non ZTK Convertible for the first time.
I am 486. I was hoping to get in the 10s. It looks like my 60ft isn’t also that bad. Weather was like 77 degrees and 90 percent humidity wich should relate to a DA of 1351 with an elevation of 105 ft. How would you rate this time? Does it need weather or driver mod?
Your car is definitely fast, you just need to work on getting the 60' down into the 1.6's.
Thanks for posting! Are you M7 or A8? Stock tires? Any mods? Keep at it, you’ll be in the 10’s soon.
#33
#37
St. Jude Donor '14
A few days later, fastest quarter mile time
This should've been my 9s pass but I screwed the pooch on my launch and had to hot lap it because the track announced they were closing an hour early. I'd been sitting there letting the car cool down without having made a pass after driving an hour there. Next time!
Kilkare 2022 DA
Had I only had my 60' from the last time out!
Kilkare 2022 DA
#38
Impressive Ben, is the car still stock? What mods if any?
Nevermind, I found the thread with the X900 package. Anyone have an idea how we go about putting this in the modification section on the list? Seeing that the X900 has a lot of little mods here and there? See below:
WEAPON-X Intake system with GM Performance Air Box
WEAPON-X LT5 95mm Ported Throttle Body
Kooks 2" headers and Green catted x pipe
WEAPON-X Stage 1 Pulley
WEAPON-X Sensor Kit
160* Thermostat
Brisk Spark Plugs
Magnecor 85kv Spark Plug Wires
WEAPON-X Custom Valve Covers with improved PCV system
Elite E2X Catch Can
WEAPON-X "X900" Badges
WEAPON-X "X900" Floor Mats
Optional: Akrapovic Slip On Titanium Exhaust with Carbon Fiber Tips
WEAPON-X Sensor Kit
160* Thermostat
Brisk Spark Plugs
Elite E2X Catch Can
DebRedZR1 (07-11-2018)
#40
Moderator
Received 3,621 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Does anyone run Half Miles ?
