C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
C7 ZR1 Fast List
Old 07-11-2018, 07:57 PM
  #41
keagan
CF Senior Member
keagan's Avatar
Originally Posted by [email protected] View Post
Finally got into the 9s, 2000 DA and full aero. Both passes were made about an hour apart, first was 2000 DA and second was prob 22-2300, I'll have to look it up. That MPH on the second pass is gettin' it!
https://youtu.be/fCvcYMC5uNc
Nice Ben! Was only a matter of time. This is still with the previous package correct?
keagan is offline
Old 08-13-2018, 05:07 PM
  #42
Thomasmoto
CF Senior Member
Support Corvetteforum!
Thomasmoto's Avatar
Default fast
Very nice, congrats!
Thomasmoto is online now
The Following User Says Thank You to Thomasmoto For This Useful Post:
[email protected] (08-15-2018)
Old 10-13-2018, 01:39 AM
  #43
Nesch18
CF Senior Member
Finally got into the 10Ďs. DA was -90.
Bone stock non ZTK convertible A8
Nesch18 is offline
The Following User Says Thank You to Nesch18 For This Useful Post:
[email protected] (10-13-2018)
Old 10-13-2018, 10:17 PM
  #44
[email protected]
Supporting Vendor
Ben@WeaponX's Avatar
St. Jude Donor '14
Congrats! Launch control or no? It's faster w/o
__________________
Special FORUM MEMBER PRICING from CORVETTE'S #1 FORGED WHEEL DEALER!!
FORGELINE * HRE * PUR * ANRKY * 360Forged * ADV1 * Weld * CCW & more
Check out our Performance Parts & Packages too!
www.WEAPONXmotorsports.com
2019 ZR1 - [email protected] MPH (1st & ONLY in the 9s!)
2020 C8 order #6
2017 Camaro ZL1 A10 - Compound Boost 1200 WHP
Ben@WeaponX is online now
Old 10-14-2018, 01:15 AM
  #45
Nesch18
CF Senior Member
Yes. Farmers donít grow on every tree. Do you have suggestions how I could get a better 60 foot. I managed a 1.778 before w/o launch control but it was really hot and humid that day and it ended up being 11.133 @ 128
Nesch18 is offline
Old 10-20-2018, 04:04 PM
  #46
keagan
CF Senior Member
keagan's Avatar
Has no one tried to run an M7? All A8's so far.
keagan is offline
Old 10-20-2018, 04:57 PM
  #47
DebRedZR1
Moderator
DebRedZR1's Avatar
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Hoping to if I find a track near JAX this winter. I would like to see Half Mile times.
DebRedZR1 is offline
The Following User Says Thank You to DebRedZR1 For This Useful Post:
keagan (10-20-2018)
Old 10-20-2018, 06:59 PM
  #48
keagan
CF Senior Member
keagan's Avatar
Get em Deb! We had/have a bunch of great drivers during the C6 Z era and early C7. Is it because the car is fairly new? Not all the good drivers got their car yet? Waiting for the cooler air?
keagan is offline
Old 10-20-2018, 11:18 PM
  #49
[email protected]
Supporting Vendor
St. Jude Donor '14
Sure thing
  • Sport Mode
  • TC off
  • Stabilitrak off - ONLY If you're experienced, otherwise leave this on as it might be the only thing that saves your ace if the car goes sideways.
  • Burnout length depends on track temp with heat gun
  • Tire pressure depends on track temp with heat gun (keep in mind they'll heat up 2-3 PSI depending on previous use and burnout length)
  • Roll up, stage shallow
  • Foot brake to ride converter up to about 2K RPMs
  • Last yellow, less brake, more gas simultaneously and roll out
  • When you feel it hook, you should be flat footed!
  • Be SURE you cross the traps before braking but as soon as you cross, apply moderate pressure to slow the car down sooner which allows you to have more room at the end for safety. Once you're a little more seasoned, you can downshift as you're braking as well, but usually, Performance Shift mode will be helping somewhat too.
  • I keep in manual mode on the return lane with the RPMs higher, in lower gears to keep more air moving through in an attempt to cool it down some before shutdown (logging the entire time)
  • Lastly, don't forget to stop at the shack to collect your 9 second slip
  • When parking, pop the hood and pull the 4 - 10mm bolts in the cowl and you can set it in the hatch as this WILL HOLD HEAT IN! If you haven't seen my temp thread, if you leave it sit with the cowl on, temps will climb 20* on the supercharger lid over the next 2 hours before they start to cool back down.
Temp Info:
https://www.corvetteforum.com/forums...into-this.html
__________________
2020 C8 order #6
The Following 2 Users Say Thank You to [email protected] For This Useful Post:
ilkSurfer (10-21-2018), Nesch18 (10-24-2018)
Old 10-24-2018, 12:50 AM
  #50
Nesch18
CF Senior Member
Sure thing
  • Sport Mode
  • TC off
Temp Info:
Thanks you very much for your advice. Youíre my hero! Lol
So this happened today. DA was -302. Car is still bone stock on the MPSS tires. Didnít even change my tire pressure. I had them on 28 psi
Also had another good run with a DA of +424
I am very happy!!
Nesch18 is offline
The Following 2 Users Say Thank You to Nesch18 For This Useful Post:
[email protected] (10-28-2018), DebRedZR1 (10-29-2018)
Old 10-24-2018, 05:56 PM
  #51
keagan
CF Senior Member
keagan's Avatar
I am very happy!!
Ahhhh suki suki now! Thatís more like it! Congrats. Will update you shortly!
keagan is offline
Old 10-28-2018, 03:20 PM
  #52
E Z06
CF Member
E Z06's Avatar
Ben
Are you running the OEM calibration with the mods including the pulley as listed in previous post ?
E Z06 is offline
Old 10-28-2018, 04:01 PM
  #53
[email protected]
Supporting Vendor
St. Jude Donor '14
Great work for stock tires!
on that 10.7 pass did you let out too early or break loose? MPH is low. Just curious.
I am very happy!!
Old 10-28-2018, 04:16 PM
  #54
Nesch18
CF Senior Member
I was slightly spinning.
Nesch18 is offline
Old 10-29-2018, 10:43 AM
  #55
keagan
CF Senior Member
keagan's Avatar
Updated! Congrats again Nesch18!
keagan is offline
Old 10-29-2018, 12:12 PM
  #56
Nesch18
CF Senior Member
Cool! Iíd put it in order from fastest to slowest as well, like on the Z06 fast list.
Nesch18 is offline
[email protected] (11-02-2018), DebRedZR1 (10-29-2018)
Old 01-04-2019, 03:27 PM
  #57
TonyFiorello
CF Member
Default 2019 ZTK First Time Out
2019 ZR1 A8 Stock Tires (Michelin SS) 93% Humidity and 70 Degrees
TonyFiorello is online now
The Following 3 Users Say Thank You to TonyFiorello For This Useful Post:
[email protected] (01-04-2019), DebRedZR1 (01-07-2019), keagan (01-08-2019)
Old 01-07-2019, 12:47 PM
  #58
DebRedZR1
Moderator
DebRedZR1's Avatar
Events Coordinator
There is a Wanna Go Fast event coming up in South Florida, hopefully some Zrs will be there as more have been delivered
Old 01-08-2019, 12:19 PM
  #59
keagan
CF Senior Member
keagan's Avatar
Updated! Nice Job Tony!
keagan is offline
Old 01-08-2019, 01:02 PM
  #60
Nesch18
CF Senior Member
Can you put them in order from fast to slow? Would look a little nicer.
Nesch18 is offline
Quick Reply: C7 ZR1 Fast List
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
