Who's ready for some track testing?
#61
track alignment
My dealer, who I like, wants to do track alignment for me. DSC suggests Toe of -0.5MM. Dealer says his equipment does it in degrees. Does anyone know what -0.5mm toe is in degrees?
If it matters I am running 315/680/18F and 325/705/18R. From the calculations I have seen, tire diameter matters. I am assuming that what DSC recommends is for the stock Cup2 Z06 tire diameter.
thanks, paul
thanks, paul
#63
My factory rear caster was .7 left side and .1 right side.
Here’s the rest of the settings before we adjusted to DSC specs...
As received from factory.Rear caster... L 0.7 / R 0.1
#64
thanks, paul
thanks, paul
desmophile (05-25-2018)
#65
The Consigliere
Received 5,432 Likes
It's disappointing the factory hasn't tightened these alignment specs.
RoketRdr (05-25-2018)
#66
Was rear caster on a separate screen or sheet? It's not listed on the screen shot under "Primary Angles/Rear".
#67
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Sean that is sad GM cant even get the rear caster close on a ZRI. Half the C7's we align have the caster is way off and never are they equal from side to side. With that said I would NEVER track a C7 without first having that checked.
G fix needy (05-26-2018)
#68
Track Rat
The alignment from the factory on the ZR1 looks just like the Z06 and GS alignments. Front camber was around -1.0 and rear was around -1.3. We didn't spend too much time on before measurements since we knew we needed to pull the wheels and remove UCA washers before mounting the heads for the real alignment. Here is what it read with stock alignment *after we pulled the washers*.
#69
The following 2 users liked this post by Questar:
G fix needy (05-26-2018),
ilkSurfer (06-10-2018)
#70
#71
Track Rat
Grand Sport, Z06, and
ZR1 models – do not remove
washers from front or rear upper
control arm bolts.
#72
Supporting Vendor
Nice Sean! I'm looking forward to watching developments with the new car.
Also, the Essex/AP Racing crew will be heading to VIR for the NCM event late next month, so maybe you can take me out for a spin.
#73
Track Rat
Come on by! I can at least promise you a ride. Depending on how the CCBs hold up to my two open track days at Summit Point I may have the AP Racing brakes back on the car at VIR.
#74
Received 8,919 Likes
There are no alignment machines available that measure rear caster it has to be performed manually.
Bill
#75
[QUOTE=Questar;1597271920]As Mad Dog said, none of the alignment machines measure "rear caster" so it has to be done manually. There is a special tool for this and it's actually pretty easy to measure...QUOTE]
Thanks for posting the pics of the tools in place for measuring rear caster.
It's beyond disappointing that GM can spend almost a billion $ on the factory, then skimp on a more precise alignment on a car costing $120,000+. It's a part of their quality control that needs to be done better.
Hopefully the C8 will be better in this regard.
#76
[QUOTE=G fix needy;1597277597]
Honestly most of the dealer network are incapable of doing a proper alignment on a corvette. Most are only now (4 years into production of the C7’s) getting the tool to measure rear caster and many in the dealership network still don’t know that rear caster can be adjusted or how to do it. Most of their alignment machines are not properly setup to do an accurate alignment to the tolerances “we” want... in my opinion that’s why GM sets such wide tolerances... to hide the fact the dealerships cannot achieve any better. Many of the dealership alignment machines are not properly levelled... so results are flawed... but “within tolerances”.
Think about this... my car arrived at the dealership (like all the others) with the skirts, wing, etc. packaged separately, for dealership PDI and installation. Except the rear wing requires a tool that the dealership didn’t own... they had to scramble to buy one. That just blew my mind... I don’t understand how GM does that.
#77
Track Rat
All prep items complete and I also decided to change the diff fluid before I go and again after. Tuesday we go to Summit Point for the maiden outing. Two days of open track with typically very few cars. It should be a solid run down.
If I can figure it out I'll try some live streaming during the day but worst case I'll have a debrief and track videos up afterwards.
https://www.youtube.com/channel/UCDS...199tg/featured
#78
Looking forward to seeing/hearing it...
#79
Track Rat
Also just adjusted the wing to max angle of attack. Give me all the downforce!
#80
Was just going to ask you "when's the day!" but you answered.
I hope you will document the whole day with a video. looking forward to seeing an unbiased opinion non magazine or GM employee etc, in comparison of the ZR1 v the C7Z.
Good luck, be safe and enjoy!
Poor-sha (06-10-2018)
