ZR1 oil temp at 271 degrees in two laps??
#81
Anyone see this thread over in A&RR about built LS7s getting much hotter even with a bunch of aftermarket cooling fixes?
https://www.corvetteforum.com/forums...ping-cool.html
BTW, here is an oil test off my 2015 C7Z after 17 hours of track time.
#82
Hold the phone. 17 hours is equivalent to ~10 track days. Are you saying you used the same oil for 10 track days in a row? If not, did you drive 10 track days, put fresh oil in and then tested? GM says to change oil after every track day. Oil consumption alone would have eaten the entire batch of oil in 10 track days.
As for your comment that "oil consumption alone would have eaten the entire batch of oil"... I experienced very little oil consumption last season... over the entire season (@ 9 or 10 track days total) I don't believe I had consumption even approach 1 quart.
#83
#84
28k miles on my 2015 Z51 with 40+ DE events. oil changed ~every 20 hours. Zero issues.
7k miles on my 2018 Z06. oil changed twice. 6 - 8 DE events so far not including chase/pace for charity laps. Zero issues.
#85
#89
So....having read all 5 pages of this thread. I am still unclear.
Is the 271' Oil Temp anything to write home about?
I suppose the real question is (with our Vettes running hot generally) - at what point is the Oil Temp or Water Temp a cause for worry? Rather, at what Fahrenheit's?
#91
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
He'd probably get along spectacular with the angry old GS owner I asked if his Vette was an extension of his non existent.............
#92
You Too!? ;)
(Don't let it come to a head!?)
