X Pipe
X Pipe
Is the ZR1 x pipe the same as the Z06? 2 & a 3/4 with a single "X"?
MustOBeenYellow2015Z (06-04-2018)
St. Jude Donor '14
https://weaponxmotorsports.com/produ...nt=37647884305
MustOBeenYellow2015Z (06-05-2018)
Is the X-pipe a cat delete too? IE: Not CA smog legal?
-Yes, CA does visual inspection. The thoroughness of that visual inspection probably varies, but I know they look for anything non-stock under the hood (compared to pics on their computer screen) and they know how many cats to look for from the same database. Further: Wouldn't removing these cats affect emissions? These aren't like the US-only header cats on my Z4 MC's S54 that only exist because of non-EU cold start emissions testing. I would think that downstream cats would make the tailpipe sniffer fail.
Theta has posted that removing the X pipe with its cats (putting in a replacement one without cats) will not result in a sniffer test fail.
What Theta has posted, has always been 100% in my book!
MustOBeenYellow2015Z (06-06-2018)
Sucks on the visual inspection...
Is the replacement X-pipe substantially re-designed from GM's or is its benefit primarily that the cats are gone?
IE: If someone were to bore through the cats...
Now that I think about it though...the X Pipe is located under a plate and I don’t think a visual inspection would reveal any change unless this were taken off...so you might not have an issue with the aftermarket X Pipe...
I am also curious how much louder the car is with the secondary cats deleted. Anyone take before/after vids?
I read somewhere on the forum that the cats were hollowed out and it didn't sound good because the hollowed out chamber of the cats resonates alot.
Received 1,335 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Not true at all, at least on the previous model ZR1, it sounded great. No resonance but I don't know about air flow/turbulence.
