Summit Point Track Day Report - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Old 06-13-2018, 01:29 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Finally broke my Z06 PB and in to the 1:14's. This was a 1:14.9 but the data shows a theoretical 1:14.6 between the two fast laps that outing. I was overdriving the car a bit that outing so it's not the smoothest driving.
Poor-sha is offline
The Following 4 Users Say Thank You to Poor-sha For This Useful Post:
johnglenntwo (06-14-2018), PRE-Z06 (06-13-2018), Racingswh (06-13-2018), Telepierre (06-14-2018)
Old 06-13-2018, 02:33 PM
Dave Schotz
CF Senior Member
Dave Schotz's Avatar
Nice progress! Enjoy the updates, keep em coming!
Best Regards,
Dave
Dave Schotz is offline
Old 06-13-2018, 03:23 PM
RUQWIKR
CF Senior Member
Someone asked earlier, but, I did not see the answer: were you on 93 or 100 octane? Thanks for sharing the info, video, etc.
RUQWIKR is offline
Old 06-13-2018, 03:31 PM
Poor-sha
Track Rat
Poor-sha's Avatar
93 octane.
Poor-sha is offline
Old 06-13-2018, 03:34 PM
RUQWIKR
CF Senior Member
Originally Posted by Poor-sha View Post
93 octane.
Would be interesting to see what the difference with 100 octane makes, if any. I see the Owner's Manual says 100 octane is recommended.
LT5 Engine : 93 octane (or higher)
unleaded gasoline is required.
100 octane (or higher) unleaded
gasoline is recommended to
maximize powertrain performance
and improve longevity of
components within the powertrain
RUQWIKR is offline
Old 06-13-2018, 03:43 PM
jvp
jvp's Avatar
"Ask Tadge" Facilitator
It wasn't really hot enough to matter; the 100 octane isn't going to suddenly give you more "go juice". It's just going to delay the onset of timing being pulled. But it's cool enough now (low 80s*) that it wouldn't matter enough.
And 100 octane at the pumps at Summit was about $8-9/gallon, last I remember. Ouch!
jvp is offline
Old 06-13-2018, 03:47 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Yeah, it basically doubles your fuel costs and I just went through 16.7 gallons in 30 minutes on track (more on that to come).
Poor-sha is offline
Old 06-13-2018, 04:22 PM
badhabit_wb
CF Senior Member
Sean if you want to check out the seats in my car at VIR you're welcome to. I have a harness bar and six point harness so that should help you decide if it's worth it.
Herman
badhabit_wb is online now
Old 06-13-2018, 04:28 PM
Mad Dog 24
CF Senior Member
Mad Dog 24's Avatar
Sean what kind of temps is the car at after some back to back hard runs?
Mad Dog 24 is offline
Old 06-13-2018, 05:37 PM
Poor-sha
Track Rat
Poor-sha's Avatar
I decided to go for an endurance run to see how long it take for a tank of gas. I ended up coming in at 30 minutes and the fuel gauge was still showing about half a tank. However, as I came down pit lane and by the time I made it to the fuel pumps it was sitting on empty. Don't trust the fuel gauge on long track stints.
My Z06 was pretty consistent at 11 gallons in 30 minutes. The ZR1 consumed 16.7 gallons in the same period of time. This was running largely 1:16-1:17 laps which are a couple seconds off my best but were something I could maintain.
Poor-sha is offline
Old 06-13-2018, 05:44 PM
badhabit_wb
CF Senior Member
We're going to need a bigger tank! Or is that boat? I doubt you'll get 30 minutes at VIR.
Old 06-13-2018, 07:38 PM
sammyv
CF Senior Member
sammyv's Avatar
Thanks for the post! Great driving!
sammyv is offline
The Following User Says Thank You to sammyv For This Useful Post:
Poor-sha (06-13-2018)
Old 06-13-2018, 07:44 PM
  #33
Bob U
CF Senior Member
Bob U's Avatar
Quick update on this before everyone gets too excited. Yesterday I did two sessions in PTM modes with the DSC controller and had no issues. This morning I can't get the PTM modes to come up. I've put the stock controller back in for today while we figure this out.
Can you tell us how the DCS compares to the stock one, did it effect your lap times?
Bob U is offline
Old 06-13-2018, 08:51 PM
  #34
Vernon
CF Senior Member
Vernon's Avatar
Thank you for the updates. Nicely done with that great beast!
Vernon is offline
The Following User Says Thank You to Vernon For This Useful Post:
Old 06-13-2018, 09:54 PM
  #35
Poor-sha
Track Rat
Poor-sha's Avatar
The main thing I noticed with the DSC controller was that the car was more stable under braking and in fast transitions. It does seem like the ZR1 is going to need some tweaks to the tune to adjust for the rear wing. Mike and I were all set to start working on those changes when I discovered that PTM modes wouldn't come up so I went back to the stock controller. All the testing today was with the stock controller.
Coolant temps would stabilize at 219F. Oil temps stabilized at 273F.
On the full fuel load run the trans fluid temp reached 307F but that was the only time I saw it that high. Usually it ran in the 270-280 range.
I'm pretty beat so a quick update on a couple of other things before I forget.
First, the no lift shift works much better in the ZR1. There's none of that jerky throttle cut out like there was in the Z06. It's just smooth.
Second, the understeer I complained about yesterday was largely gone today. I'm not sure exactly why but the track conditions were different.
Poor-sha is offline
The Following User Says Thank You to Poor-sha For This Useful Post:
Mad Dog 24 (06-15-2018)
Old 06-13-2018, 10:15 PM
  #36
Questar
CF Senior Member
Questar's Avatar
Sean... I didn’t lower my front suspension (as you did) but ran last week with maximum rear wing AoA. I did not get the sense that mine was understeering but I’m not as perceptive as I suspect you are. So I’m wondering whether to adjust the wing to one setting less or to leave it as is. With my front suspension a bit higher than yours my rear wing is a bit less angled, if I adjust it do you think I’ll be taking too much downforce off the back end and get an oversteer condition? I’d rather have understeer than oversteer.
Questar is offline
Old 06-13-2018, 10:19 PM
  #37
Racingswh
CF Senior Member
Racingswh's Avatar
Great driving Sean!! Thanks for all the updates. I know so many of us really appreciate you taking the time to do this. Car runs as great as it looks!!
Racingswh is online now
Old 06-13-2018, 10:20 PM
  #38
Poor-sha
Track Rat
Poor-sha's Avatar
Originally Posted by Questar View Post
Sean... I didnít lower my front suspension (as you did) but ran last week with maximum rear wing AoA. I did not get the sense that mine was understeering but Iím not as perceptive as I suspect you are. So Iím wondering whether to adjust the wing to one setting less or to leave it as is. With my front suspension a bit higher than yours my rear wing is a bit less angled, if I adjust it do you think Iíll be taking too much downforce off the back end and get an oversteer condition? Iíd rather have understeer than oversteer.
In theory lowering the front end should make the front aero work better so I would have expected your understeer to be worse than mine. I'd be inclined to try it both ways and see what you think. Luckily it's a 2 min job to change the wing angle.
Poor-sha is offline
Old 06-13-2018, 10:32 PM
  #39
Bob U
CF Senior Member
Bob U's Avatar
After looking at your temperature data strip, the Intake Air Temp is only running a few degrees warmer then the Outside Air Temp.
Is the Intake Air Temp coming from the MAF sensor?
How does this spread compare to the Z06?
Thanks for the data.
Bob U is offline
Old 06-13-2018, 11:13 PM
  #40
OnPoint
CF Senior Member
OnPoint's Avatar
Nicely done, Sean. Always good to have your data and knowledge shared with the forum.
OnPoint is online now
The Following User Says Thank You to OnPoint For This Useful Post:
Questar (06-13-2018)
Quick Reply: Summit Point Track Day Report
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
