C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Those who have and those who are going to
Old 08-05-2018, 12:37 AM
Kinsale
Kinsale's Avatar
Default Those who have and those who are going to
Let me be the first to admit of scraping the bottom of the splitter only two days home. I can't tell when it happened or where it happened, but It is scrapped. I was able to buff 60 percent out, but extremely hard to get a jack underneath to lift the front enough to get a buffer on it. So, there you have it. Will buff more out when able to get it on a lift, which almost all of it will come out. It is not noticeable, but am I p----d. With that said, it's going to happen just hope you don't crack it.
Old 08-05-2018, 08:36 AM
zedbyers
zedbyers's Avatar
i wish they made this thing out of cheap plastic. tear it up, and replace it as needed. no need for CF here, we aren’t professional racers that just go get a new one out of the truck and replace it.
Old 08-05-2018, 08:47 AM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
it's relatively easy to wear through it if you scrape it a lot and then you end up with jagged pieces of CF and a hole on the underside of the splitter. I ended up putting some black duct tape to cover the hole until I can get a new splitter. It was an issue with the Z06 too but just the leading edge was CF and the undertray that met up with the splitter was plastic. With the ZR1 the carbon fiber wraps around and under the splitter which means it does a lot more damage.
Luckily I've only had issues with rubbing at one track. Just got some pictures last night from that event.
The following 4 users liked this post by Poor-sha:
DebRedZR1 (08-05-2018), ilkSurfer (08-05-2018), Racerdj (08-05-2018), Telepierre (08-05-2018)
Old 08-05-2018, 08:57 AM
Racerdj
Racerdj's Avatar
Stunning pictures!
Kinsale (08-05-2018)
Old 08-05-2018, 09:12 AM
TopSpeedNeed
TopSpeedNeed's Avatar
Awesome pictures...
customryder (08-05-2018)
Old 08-05-2018, 09:14 AM
Kinsale
Kinsale's Avatar
Those are some awesome pictures, great photography. All four wheels off the ground is just plain cool. Thanks for sharing.
Old 08-05-2018, 09:42 AM
Vernon
Vernon's Avatar
Yeah, those pics are fantastic.
Maybe Tadge would like one for GM/Chevrolet marketing.
Old 08-05-2018, 09:53 AM
Newton06
Newton06's Avatar
Sean those are awesome pics!
How did the car feel going airborne?
Old 08-05-2018, 10:00 AM
sammyv
sammyv's Avatar
Nice!
Old 08-05-2018, 11:02 AM
Poor-sha
Track Rat
Poor-sha's Avatar
Very drama free. The biggest concern is that there is a curve leading up to the crest so I typically left the ground pointed off track to the right. You need to trust that you have enough track width to turn back to the left after you touch down and don't land with the wheels turned.
I'll create a separate thread for these pics so I don't derail the OPs post any further. It was just too cool not to share.
Old 08-05-2018, 11:27 AM
Vernon
Vernon's Avatar
Has a source for a less costly splitter been marketed/found so as to remove the factory splitter for storage?
To Those who have and those who are going to
Quick Reply: Those who have and those who are going to
