ZR1 M7 ZTK Coupe on the scales
I got a chance to put the ZR1 on some scales yesterday. 3615# full of fuel. Car has the comp seats also. Shipping weight on paperwork was 3501#. FYI.
The following 9 users liked this post by REACTOR111:
Corvette_Nut (08-17-2018),
Hawkbarr (08-25-2018),
HorsePowerAddicts (08-17-2018),
ilkSurfer (08-17-2018),
JMB (08-17-2018),
and 4 others liked this post.
ZoratZ06 (08-17-2018)
6.3lbs per gallon of gas x 18.5 gallons = 116.55lbs.
3615 - 116.55 = 3498.45. I'd say within 2.5 lbs is pretty accurate. 3501 vs. 3498.45
https://www.fueleconomy.gov/feg/cont...es/co2_inc.htm
The following 2 users liked this post by ZoratZ06:
NW-99SS (08-22-2019),
the professor (08-22-2019)
I'd say that it dang accurate considering they ship these cars with probably only a gallon or 2 in the tank.
Awesome, thanks for doing that. I predicted that 1ZR vs 3ZR would be about 30-35 lb delta. Looks like it's right in there at 32 lbs.
So here are the weights I know of relative to the ZR1.
88 lbs - ZR1 vs Z06
55 lbs - 18" wheels and slicks vs stock wheels and run flats
32 lbs - 3ZR vs 1ZR
88 lbs - ZR1 vs Z06
32 lbs - 3ZR vs 1ZR
Awesome, thanks for doing that. I predicated that 1ZR vs 3ZR would be about 30-35 lb delta. Looks like it's right in there at 32 lbs.
88 lbs - ZR1 vs Z06
32 lbs - 3ZR vs 1ZR
88 lbs - ZR1 vs Z06
32 lbs - 3ZR vs 1ZR
The 18" wheels (Finspeed front, CCW rear) with Pirelli scrubs were 55 lbs lighter than the OEM ZR1 wheels with Cup 2 tires. The Forgeline 18"s I have might even be a tad lighter.
Newton06 (08-18-2018)
88 lbs - ZR1 vs Z06
32 lbs - 3ZR vs 1ZR
88 lbs - ZR1 vs Z06
32 lbs - 3ZR vs 1ZR
Were the 1ZR and 3ZR weighed on the same scale?
Did either/both have comp seats?
Were either/ both auto's or manuals?
Did either have chrome wheels (OK, just kidding on this one)
I would have assumed a 1ZR would have been more than 32 pounds lighter than a 3ZR. That's not even a 1% variance
Thanks for any additional information you can add!
**** Disclaimer: The only option our 1ZR came with was the gas guzzler tax...…….Seriously
Just curious..... "HONESTLY"
Thank you... no harm in saying you don't know
Besides, a good driver is worth a ton
Get Tillet racing seats which are under 10 lbs, can get that car in the low 3400s. Does the ZR1 have carbon driveshaft? Hmm, what else can get that weight down? Stronger lighter wheels from forgeline too. I think by then youll be in the 3300lbs range.
Go to Katech Z06 weight reduction thread. Lots to lose. Quick list:
-full titanium exhaust
-carpet
-lightweight flywheel and clutch assembly
-racing seats
-plexiglass front, rear and qtr windows.
-roof skin vs full roof.
-light battery
-brakes
That's without completely stripping the car. Lightweighting without stripping costs A LOT.
serpent (08-30-2019)
